Success!
I found one coppermine that works stable @ 166 MHz with overvolting!!! 😁
It's one of the latest revisions: SL5FQ with cD0 stepping!
This one is pretty odd... At first I thought it's a Tualatin one - it has an IHS just like the one used on Tualatins, but the core is coppermine... and it is not a Coppermine-T. Just coppermine 😉
Take a look:
http://www.chipdb.org/data/media/845/Intel_Pe … INES_pinkie.jpg
What is also surprising for me is the fact that it doesn't get really hot! In BIOS the highest temperature was 51. In Everest the temperatures are wrong... I used simple AIR cooling. Nevertheless I stressed it for more than 1,5 hour! ZERO problems! 😉 Did some benchamrks tried different graphics cards, I even overclocked them - everything just works fine!
![32002.jpg](http://u.cubeupload.com/roksana/32002.jpg)
![4Stability.jpg](http://u.cubeupload.com/roksana/4Stability.jpg)
The results from 3D Mark 2001SE are astonishing! At default clocks it was 7823!!!!
![12001166PCUTi4600.jpg](http://u.cubeupload.com/roksana/12001166PCUTi4600.jpg)
Here is what I got when I overclocked Ti4600 a little bit
![22001SE166PCUOCKARTA.jpg](http://u.cubeupload.com/roksana/22001SE166PCUOCKARTA.jpg)
I even managed to run and OVECLOCK Radeon 9800 PRO to the clocks of Radeon 9800XT
![53f0radzio9800XTclocks.jpg](http://u.cubeupload.com/roksana/53f0radzio9800XTclocks.jpg)
Will a Radeon9800 PRO run on an overclocked AGP frequency of 83 MHz and be able to overclock itself so much?
Johnylyr wrote:Which motherboard do you own that supports 166MHz with correct AGP divider?
I am afraid I can't tell you at this moment... sorry. I have to be 100 % sure that the right dividers are there, but so far I couldn't find any software that would prove it... I also have been working on a project related to this motherboard for a several months now, and I don't want to spoil anything... Just please be patient and wait untill the end of the year, I should be able to prepare all the rusults I got so far! It's going to be big!
