Reply 26660 of 53026, by liqmat
vlask wrote:
1]Use tripod and delayed shutter - 2sec is enough 2]Take photos at daylight, usually close to window (outside is better, but in […]
MMaximus wrote:
Nice cards! I'm afraid I can't answer any of your questions but I have one for you 😀 - How do you take pictures of your cards? They're very good quality! It looks like you scan them somehow? I've tried on my flatbed scanner but the results are very poor. So I default to taking pictures with my DSLR and an external flash - however I'd like to get results closer to yours where the light is a more even and there aren't any perspective issues.
2]Take photos at daylight, usually close to window (outside is better, but in winter not comfy....). Flash is useless, it reflects a lot on PCB. You can try some lights, but they needs to be done from all sides and soft. Not easy and cheap to do.
3]Leave some space on sides, don't zoom max to the edges, this usually does undesired efects (they can be solved in Photoshop using lens correction plugin).
4]Use RAW format if available, then in import move shadows slider till they almost dissappear (usualy is PCIE/AGP port in shadow because of coolers). Then use also sharpen plugin.
Still my photos are not always as sharp as i want them and i must do corrections about shadows and sometimes little lens corrections. Better lightning would be great, but commercial will be expensive and i rather invest into more cards....
Excellent advice. I'm lazy and usually use my phone instead of my good camera. I have one thing to add to your list.
5.) Don't concentrate so much on megapixels. Instead, get as big of a sensor as you can afford. So many people make this mistake and only look at what bazillion megapixels the camera has.
Reply 26661 of 53026, by cyclone3d
MMaximus wrote:
vlask wrote:
Got 2 profi cards and and same amount of questions for you 🤣
If you want to use a scanner to take pics, you need a CCD based one and then you also need to make an enclosure to put the stuff under so no other light can get in. A cardboard box works great.
You can get very nice pictures like this.
As was already said, flash ruins everything.
For DSLR, I don't use natural lighting as it is much easier to use artificial lighting which also doesn't have to cost very much at all.
For the light enclosures, I use these which can be had for less than $10 a piece:
36.75 KiB
I use CFL or LED bulbs with "daylight" color temperature.
The backdrop can be whatever color as long as it is not glossy.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 26662 of 53026, by Intel486dx33
Desktop Computer with AMD AM5X86-P75 ( Restore project ).
Why? Because I was looking to build a am5x86 computer and found this entire system for dirt cheap.
and a Sound Blaster Vibra16s ISA with Yamaha OPL 262.
    547.38 KiB
    323.13 KiB
    302.97 KiB
Reply 26663 of 53026, by Ozzuneoj
Okay, who bought the Hercules Stingray Pro VL card, sealed in box on ebay? I'm not really a "sealed box" collector so it wasn't worth that much to me, but for $100 it was probably a steal, going by the sale prices of other high end VLB cards ($200+ for a loose ET4000W32i... yikes). I think ARK1000 VLB cards are super rare and they have to be the absolute fastest thing on VLB (ARK1000 is great on PCI). This is a card that really deserves to be used, which IMO, makes a sealed card a tougher sell than one that is unused but open box. Knowing how serious "sealed box" collectors can get, I'd feel a little odd cutting open the box for an incredibly rare card just to get a 10% performance gain in a few old games that would probably work better on a PCI system anyway.
Reply 26664 of 53026, by hard1k
In such moments I always refill my tanks of hatred towards those bastards who are guilty for the closed eBay thread...
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 26665 of 53026, by hard1k
Anyway, it's New Year today, so I thought that nobody was going to give me a present as nice as I would myself, so I bought this (seller's pic):
161.18 KiB
It even has sort of a New Year tree! 😁
AWE64 Legacy
Reply 26666 of 53026, by SEGamer
Not entirely retro, but these ECS Hydra cards finally came in from Russia. I honestly thought these never made it to market since all I can find are some reviews on them.
1.93 MiB
Also came with the Thermaltake pump that ECS just slapped a Hydra sticker on. I'm sure the 9800 coolers are rebranded as well, but still a neat kit for the day.
Unfortunately no box, but I might see if I can make a repro of it somehow.
NintendoAge | VCFed
Reply 26668 of 53026, by MMaximus
Thanks for all this info - it's much appreciated! I think some corrections are always necessary, especially when you shoot RAW. It's ok as long as it's not overdone 😀 I shoot hand-held for lack of a correct tripod attachment but I know my pics would really benefit from tripod use.
cyclone3d wrote:
If you want to use a scanner to take pics, you need a CCD based one and then you also need to make an enclosure to put the stuff […]
Thanks for the advice. I actually didn't think about an enclosure but it totally makes sense. I have a CCD based Epson scanner so I'll see if I can find something suitable.
As per flash, I think it can work as long as you bounce it. I usually bounce it off a wall but it's true that it would probably look more natural if there were more than one light source.
Hard Disk Sounds
Reply 26669 of 53026, by oeuvre
Dell Optiplex GX280 tower... turns on but no post/video/beep. These leaky boys....
Reply 26670 of 53026, by Intel486dx33
Those GX280 are Notorious for caps going bad. I bought some NEW motherboards on eBay for mine for cheap.
Check it out.
https://www.ebay.com/itm/DELL-OPTIPLEX-GX280- … sUAAOSwF1tcIfD2
And
https://www.ebay.com/itm/DELL-OPTIPLEX-GX280- … 0gAAOSwfXBZt-pw
Reply 26671 of 53026, by bjwil1991
I have 4 bloated caps in my Dimension 4550, yet, it still runs.
Reply 26672 of 53026, by oeuvre
Intel486dx33 wrote:
Those GX280 are Notorious for caps going bad. I bought some NEW motherboards on eBay for mine for cheap. Check it out. https://w […]
Check it out.
And
Thanks. Bought the cheapest one I could find. https://www.ebay.com/itm/192515477104
Reply 26673 of 53026, by Thermalwrong
Today's one is somewhere between "What I've been doing" and "Bought this (old stuff) today"
I decided to buy a second, "not working" Advantech 6145 SBC because it was cheap and I worked out the jumpers indicated it was either a DX4 100 or 5x86. Thankfully the gamble paid off!
When I got it, the CPU fan, which clips on, was seized and while I got it spinning with some oil, it vibrates terribly when running, I guess the sintered bearing is too worn out to work well.
The CPU fitted turned out to be a nice late model x5 133 chip, and with a FIC VIP IO2 board on its way to me, I'm going to have some fun overclocking some old computers soon 😁
Upon powering, the board beeped angrily at me, which turned out to be a broken EDO ram stick. Unfortunately though, when I replaced the RAM, it would then indicate it was booting on the POST card, but no display, what could be causing that?
1.95 MiB
This is where I really like having two of something, sadly I don't have an EEPROM programmer yet but swapping the EEPROMs between the two boards, I got video output once I swapped them over. Hooray! My "not working" SBC is now working 😁
(now to buy an EEPROM flasher... or maybe, if it's booting, an auto loading BIOS flash?)
Also bought some of these because it's cheaper than buying ISA slots, which I now need to make ISA connectors for these & other projects:
10.65 KiB
Reply 26674 of 53026, by liqmat
161.18 KiB
That is a thing of beauty right there.
Reply 26675 of 53026, by liqmat
SEGamer wrote:
liqmat wrote:
Not a terrible price. Shipping isn't terrible either coming from the Ukraine. Tempting.
Yep, I bought one last week to replace a PC Chips M919 board since it's really picky with detecting the M919 cache stick. I think I need to get fast page RAM for it but all I have is EDO at the moment.
Well, I couldn't resist and I bought one as well. Let's hope they are working boards. Great price if they are.
Reply 26676 of 53026, by arncht
one of the best AT psu. a nos fsp 300w. classic "old" look - it will be fine, as a primary psu to my 486 😀
    1.04 MiB
Overdoze of the demoscene
Reply 26677 of 53026, by appiah4
Ever since I traded my Mystique 220 away its absence was a pain on my side.. I saw this part listed on eBay from an eastern Europe country, the price was very low, I made an even lower offer and it got accepted; so here I am, proud owner of not only a Mystique but also a Rainbow Runner!
Not sure whether it's a regular or a 220 though. Conventional wisdom says Mystique is 1064SG and Mystique 220 is 1164SG but my previous card was a Mystique 220 with a 1064SG chip, so.. Not sure how to tell them apart.
Reply 26678 of 53026, by Cyrix200+
Was happy to take it just for the CPU, but then the guy said he also had the rest of the system. Bought it all. Unfortunately, he disassembled it completely. Fortunately, he still had everything (he thinks).
Will have to puzzle it back together. Curious to see if it might be useful as a DOS machine, compact, silent, has a floppy drive (not pictured), ISA slot.
1982 to 2001
Reply 26679 of 53026, by Intel486dx33
VLB motherboard "Made in U.S.A."
Does anyone know anything about this motherboard ?
It appears to be missing the CMOS battery ?
With Intel 486dx2-66 CPU.
    762.48 KiB
    288.07 KiB
    429.92 KiB
    407.45 KiB
    395.26 KiB
