First post, by Baoran
I tried making dual boot win98 and winxp but I failed. System has 2 hard drives. First I installed win98 on the first hard drive and when I had it fully working, I tried installing windows xp on the second hard drive. Installation failed and got stuck so I was not able to install winxp there. So I just emptied the second hard drive and even removed the partitions there. Now the problem is that winxp installation attempt left winxp boot menu on the first hard drive where you choose the OS to boot with just 1 second timer which is annoying.
How can I remove the winxp boot menu that was left behind that I can at least use win98 normally?
