First post, by ruthan
Hello,
i wonder, where to here screws as on picture, i tried to find them on Ebay but i failed, maybe i only not know right keyword..
The attachment img_7245.jpg is no longer available
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 1 of 4, by PC Hoarder Patrol
Try searching for screwed spacer sleeve - you can get them in various lengths and with a variety of threads.
Reply 2 of 4, by ruthan
Thanks, but i found only generic not pc ones, and pci card height is regarding the specs any typical 107 mm, plus some stand screws for MB, it would be something like 112-115, so without any cutting or lots of additional washers, it wouldnt be useful..
Reply 3 of 4, by martin_boro
From what I understand, your best chance is to cut the necessary length out of a threaded rod and then use a few nuts to secure the card in.
There is no set standard for anything like this, so that is your best chance tbh.
Reply 4 of 4, by ruthan
Well, i hoped that some Chinese guy was clever enough to make living from making these, if not it will happen in few months..
