First post, by Almoststew1990
- Oldbie
I'm trying to get my chipset drivers installed on my fresh Windows 98SE install, but whenever I install the readily available latest release v1.21, it gives me a Windows Protection Error. The drivers are from 2005... I have struggled to find an earlier version of the driver.
However, the 1.21 driver folder has a folder within it called "old", and the driver in that folder is dated 2002. How can I make the setup utility install that version instead of the current version? The 1.21 drivers are in a folder called current, I assume the installer looks into that current folder. Could I just move the contents of the old folder to the current folder?
