First post, by jforrest1980
I am attempting to install CTmouse into DOS. This is my first attempt at something like this, so I really need some detailed instructions. I have read over the CTmouse documentation, and I am not seeing any step-by-step information on how to install. This will be on a Windows 98SE machine, which I will boot into DOS for the install. I will also be using a GOTEK Floppy drive emulator.
So I have my floppy emulator drive installed, and I have the software with a ready formatted USB stick.
I downloaded CTmouse 2.1 from here http://cutemouse.sourceforge.net/
Here is where I start to get confused. I extracted the file, and there are 3 folders in there "BIN, Doc, & Source"
1. Do I copy/paste all 3 of those files to a floppy file, or is there a specific file I need to install?
2. Do I just copy/paste, or do I need to save the file to the GOTEK floppy file as a "image"
3. Once I finally get the correct files on the floppy USB, what are the steps exactly once in DOS to get this installed? I understand how to navigate folders in DOS, but once I am in the floppy directory, I am not sure what to do.
Thanks in advance.
