First post, by Muz
The project is in Java, compiled it in NetBeans, with DB Browser for SQLite. It is a Bank Management System. I tried submit it to my lecturer, but she said the project do not have enough functions. What kind of functions should I add more to the project? The software could deposit, withdraw, accounts, etc.
Note: In order to install NetBeans, you need JDK installed in your computer.
If you like to run the application of the project, you can browse to my file attached here, and go through the dist folder, and open the JAR file.
http://www.mediafire.com/file/din0tajuu6n630f … System.zip/file
