Zotac's GT220 driver for Win2k?
Discussion about old graphics cards, monitors and video related things.
Postby deksar » 2019-1-10 @ 17:41
Dear friends,
I'm looking for Zotac's GT220 PCI VGA (1GB) drivers for Win2k Professional. I'm sick and tired of looking for that. Does anyone has any idea/link regarding the topic?
Card: https://www.zotac.com/lk/product/graphics_card/gt220
Many thanks in advance!
deksar
Re: Zotac's GT220 driver for Win2k?
Postby dr_st » 2019-1-10 @ 19:23
Such a driver does not exist.
User avatar
dr_st
Postby deksar » 2019-1-10 @ 19:50
There is absolutely no NVIDIA GT 220 driver for Windows 2k?
deksar
Postby BinaryDemon » 2019-1-10 @ 21:41
I have no experience with either option I'm suggesting but:
1) Looks like there are some modified Nvidia drivers which *may* work: http://blog.livedoor.jp/blackwingcat/ar ... 14373.html (Some versions require KernelEx patched OS)
I'd atleast try this - http://w2k.flxsrv.org/cgi-bin/dl.cgi?file=nv2k19745.exe , doesnt appear to require KernelEx
2) If you don't need 3D acceleration, you should be able to find Universal Vesa drivers - http://bearwindows.boot-land.net/vbemp.htm
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
BinaryDemon
Postby deksar » 2019-1-11 @ 07:39
BinaryDemon wrote:I have no experience with either option I'm suggesting but:
Wow, THANK YOU SO MUCH, BinaryDemon! It worked! Your suggestion has successfully installed my VGA card! There are a lot of users all around the Internet forums looking for that thing, as I've seen recently.
So in case if someone happen to appear here from Google, what I did:
-First, (nv2k19745.exe needs that) I installed Update Rollup 1 for Windows 2000 SP4(v2) on my Windows 2000 Pro SP4. Got it here: http://w2k.flxsrv.org/cgi-bin/wluc.cgi? ... =/&KEY=SRP
-Then I downloaded and ran nv2k19745.exe from http://blog.livedoor.jp/blackwingcat/ar ... 14373.html
Thanks once again.
P.S: dxdiag reports that Direct 3D is not enabled. Perhaps that's because the default low version of DirectX on the system? (ver.7 something). I'm going to update it to directx_feb2010_redist.exe which is the latest one for Win2k I assume.. I'll keep here updated.
deksar
Postby deksar » 2019-1-14 @ 12:13
I don't know if I'm asking too much...but, now is it possible to find the same card's Win98SE driver? I failed...
Many thanks!
deksar
Postby Mr. horse » 2019-1-14 @ 13:05
You can use older xp drivers if you manually install them from the device manager.
No sir I don't like it!
Mr. horse
Postby deksar » 2019-1-14 @ 13:10
Mr. horse wrote:You can use older xp drivers if you manually install them from the device manager.
Using XP drivers for installing Nvidia GT 220 card on Windows 98SE? I don't really think that would work.
deksar
Postby oeuvre » 2019-1-14 @ 14:38
He meant using an older XP driver on Windows 2000.
HP Z420 Workstation Intel Xeon E5-1620, 32GB, AMD FirePro V7900 2GB, SSD + HD, XP/7
Main Desktop Intel i7 6700, 32GB, AMD RX580 8GB, NVMe SSD + HD, 10
User avatar
oeuvre
Postby Kristallbaldr » 2019-5-15 @ 13:34
Hello can anyone help me please I am new. The Drivers on Japanese Page are down.
deksar can you help me. Greetings
Content: nVIDIA 197.45 WQHL Desktop Driver Full
Filename: nv2k19745.exe
Language: Multi
LastUpdate: 2010/06/1
Download size: 102M
Version: 1.0
Require: Windows 2000 SP4 +SRP1v2
Kristallbaldr
Postby oeuvre » 2019-5-15 @ 13:52
Google is your friend. I found it in 2 seconds. http://blog.livedoor.jp/blackwingcat/ar ... 14373.html
User avatar
oeuvre
Return to Video
Who is online
Users browsing this forum: danijelm, Dropcik, mpe and 1 guest
