First post, by AEV80
Hi guys, I've put an AT power only Socket 7 motherboard in an ATX case with an ATX PSU.
I'm using an ATX to AT adapter cable which feeds thru to a normal on/off switch.
I'd like to be able to use the momentary power switch on the ATX case instead.
Could someone point me in the right direction to buy an adaptor board / cable for this or some DIY instructions to make my own?
