First post, by fsmith2003
Just acquired but have yet to pick up an old Apple IIe. I have boxes of C64 Single Sided/DD floppies from a lot I acquired years ago. My question is will I be able to use these SSDD floppies with the Apple II? I keep reading it requiresDual Sided Double Density but will the Singles work?
Reply 1 of 6, by bakemono
I'm pretty sure Apple 5.25" drives were single-sided. The floppies stored 140KB on one side.
Reply 2 of 6, by clueless1
They should work. I used to use a hole punch to to make the backside of single-sided floppies writable on my Apple IIe. 😊
Reply 3 of 6, by fsmith2003
Awesome. You have instructions on exactly how this is done by chance?
Reply 4 of 6, by clueless1
Pretty simple. Flip one floppy over on top of the other. Line up the hole punch with the write notch and punch away. 😀
The attachment floppypunch.png is no longer available
edit: more info here:
https://www.atarimagazines.com/compute/issue1 … G_YOUR_DISK.php
Reply 5 of 6, by xjas
They used to sell dedicated disk notchers for this purpose. 😜 I still have one.
And yes, C64-compatible disks should also work on an Apple II (you'll have to re-format them though.)
Reply 6 of 6, by fsmith2003
Great info guys! I can confirm the "Single Sided" disk do work on the Apple II and the notches have been made. Thanks.
