First post, by superfury
I've been running the latest test386.asm commit against UniPCemu's improved protection and instruction emulation, but now I strangely see it crashing on the very first or second paging test?
It's never done that, as far as I can remember?
Perhaps the cause is somewhere else? I see the instruction causing the Page Fault trying to move 0xDEADBEEF into the memory at logical address 49F000?
Anyone knows why said problem occurs?
Edit: Turning on the DEBUG constant(set to 1), I get in my logs(UniPCemu itself adds the timestamp in front of it):
00:05:01:78.02720: P SUPER W, SUPER W, SUPER R, #PF
So the problem is a non-present access somehow, which it doesn't like?
Edit: Just found a little bug that made the Paging unit think there were writes to memory when there were actually only reads(due to the new paging vs segmentation check being split).
Edit: Said bugfix seems to have fixed said checks. They are passing correctly now. 😁
Now the next check(12h segmentation checks?) fails.
Edit: Whoops. The segmentation checks that check for read/write/execute permissions to fault or not when accessing it's contents(e.g. CS:xxxx, checking the xxxx read/write against the descriptor) wasn't properly protected against the new bits that were added(the same problem as with the paging unit above). Thus reads/writes/executes were incorrectly throwing and not throwing faults.
Now it progresses onward to the next text, which(guess what) fails(test 1Ah in this case).
UniPCemu Git repository
