First post, by Rodoko
As the title says, I rescued from the place where I learn my computer related stuff a Nortel Baystack Instant Internet 100-s 7 port switch and I opened up and it was SO filthy that I cleaned all up and I discovered that has an embedded PC so the thing was going to be fun to play with
Inside the bad boy we have a NII-100 embedded PC motherboard sporting a Cyrix MII @ 333 MHz, 140 MB of RAM (12 MB built-in and the rest is on the 128 MB memory module that I installed), no graphics but it has a VGA pinout and no PS/2 or USB ports, kinda similar to the first wireless router that LGR covered up in a video
Also, the machine has an 8 MB Sandisk CF card containing all the software needed to run the switch which is based in Datalight ROM-DOS so it starts up pretty quickly but you need to give it some time to make the connection
The complicated thing is to find the software it needs to be managed since part of Nortel was bought by Avaya in 2005 and they only have the manuals but no software and Googling around I found an updated version of the software that was meant for this thing's sucessor so... that was a nice thing to know
The name "Baystack" originated from Bay Networks, a company which specialized in networking applications like making hubs, switches and all those kinds of things and if you didn't know, the company was bought by Nortel in 1998 but a part of it ended in a company you guys might know and that is... Netgear!!
Netgear as you know makes all networking based stuff from routers to big-ass switches
Anyhoo, I'll end this post with some pics and as well, the manual and software for the switch
The attachment IMG-20190117-WA0069.jpg is no longer available
The attachment IMG-20190118-WA0017.jpg is no longer available
The attachment IMG-20190119-WA0042.jpg is no longer available
Reply 1 of 5, by chrismeyer6
That's a nice piece of network gear you got there. How does it do with switching performance?
Reply 2 of 5, by BinaryDemon
Just 1 pci slot?
Reply 3 of 5, by Rodoko
Well, is not that bad, the issue I have to deal with is the IP issue since unlike my 3com switch, this one assigns his own IP instead of using the one generated by the ICS option in Windows
The thing has an Ethernet port on the back (Eth2 according to the switch's OS) that is where my main laptop's ICS is connected and then on the front, the N°1 port is hooked up to my 3com switch or a computer
As configuring the switch is almost a pain, you screw it up and then you need to go to the DIP switches to reset everything to default and start again so, this switch works great, the issue I need to deal is with the switch not letting me to use the ICS's IP and preventing me from seeing my drives (The drives I share in every machine I have)
BinaryDemon wrote:
Just 1 pci slot?
Yes, this introduces you to the concept of embbeded computing what this means is the PCI slot can be used for a modem or a NIC, if you plug an USB based thing, the BIOS will not initialize it since it doesn't have any PS/2 ports on it
Reply 4 of 5, by BinaryDemon
Yeah I thought it might be cool to convert these devices if they were cheap enough, but even if there was no effort made to prevent tampering there is just too much missing I/O in this case.
Reply 5 of 5, by Rodoko
Yes and has to do with the reason that it acts like a computer to manage via a Terminal app by the AUX (Serial) or via the manufacturer's software
Also this kind of thing is still going as of today with the newer switches, although they are web based instead of using a software to manage 'em
I'm not going to deny that I saw the front panel connectors on the computer side of the switch but there's no pinout for the keyboard or mouse connectors
