Retro Rig Photo Thread
Showcase your Retro PC / Build logs.
Re: Retro Rig Photo Thread
Postby PcBytes » 2019-1-14 @ 09:56
StrangeD0s wrote:
PcBytes wrote:
StrangeD0s wrote:Wow, how can you tell they are bad from this blurry photo?
Simple, I can notice the different reflection on those two as opposed to all other caps.
ASRock boards from that era tend to develop bad caps quite a lot.
So... is it worth to change the caps or better just through the whole board out? I am quite handy with a soldering iron.
If you think it's worth to replace the caps, you can go ahead and replace them, although a 848P motherboard with only 2 DDR slots doesn't sound like the best idea.
Main: Xeon X5450, 8GB RAM DDR2, DFI Lanparty DK P45-T2RS
Wolfram: C2D E6750, 2GB DDR2, ASUS P5K-SE/EPU
R.A.I.D: Pentium 4 2.8GHz, 2GB DDR400, ASUS P4C800-E Deluxe
Totem: Pentium S 166MHz, 128MB RAM, Totem TM-586TX4
Voodoo: AMD K6-2 500MHz, 128MB RAM, LuckyStar 5MVP3
User avatar
PcBytes
Postby Poulton » 2019-1-15 @ 10:21
StrangeD0s wrote: Any tips? Will a better PSU resolve the issue?
Have you tried to dedust it via compressor, compressed air or something else? These things can collect a lot of dust inside.
Other resolve: Go with a new PSU. The motherboard has the P4 power connector, so any descent modern 300W to 400W PSU can handle it.
StrangeD0s wrote:So... is it worth to change the caps or better just through the whole board out? I am quite handy with a soldering iron.
Change the caps. These old Asrock Combo Socket Boards, like the one you have, are quite interesting and hard to find.
User avatar
Poulton
Postby SW-SSG » 2019-1-15 @ 20:46
Agree, would attempt to fix if possible; these old ASRocks are very unique and worth saving, even if there are usually better options out there feature- or performance-wise if one desires certain CPU compatibility or chipset choice.
User avatar
SW-SSG
Postby NuuttiS » 2019-1-22 @ 21:02
I'm slowly building a system to play early to mid 90's games. Finally found a case with turbo switch and MHz display. Still need to get MT-32 and Gravis Ultrasound.
AMD 486 DX/2 66MHz, 8Mb RAM
Sound Blaster 16 CT1740
S3 Trio64
14" ICL shadowmask display with all analog controls for older games
19" Samsung 959NF for newer games
NuuttiS
Postby arncht » 2019-1-23 @ 13:18
this case is awesome :) i would like to find similar one.
Socket 3 VLB @ 1994.10
Socket 5 @ 1995.05
Socket 7 @ 1997.09
Slot 1 @ 2000.05
Socket A @ 2003.06
Socket 775 @ 2006.11 - Core 2 Extreme QX6700, Geforce 8800 GTX, Sound Blaster X-Fi Fatal1ty
User avatar
arncht
Postby badmojo » 2019-1-24 @ 01:57
That is indeed an awesome case, love the 90's pastel green power button. Also points gained for the period correct mitsumi CD drive.
Are you slowing the DX2 66 down for Ultima7? I found it ran too fast with all of those Mhz. System Shock on the other hand might struggle a bit at that speed?
Anyway cool system.
If it's broke, then fix it!
User avatar
badmojo
Postby oeuvre » 2019-1-24 @ 04:00
needs moar skeletor
Retro PC Intel i7 2600, 16GB, AMD FirePro V5800 1GB, SSD + HD, XP/7
Main Desktop AMD Ryzen 3700X, 32GB, AMD RX580 8GB, NVMe SSD + HD, 10
User avatar
oeuvre
Postby luckybob » 2019-1-24 @ 05:15
oeuvre wrote:needs moar skeletor
User avatar
luckybob
Postby oeuvre » 2019-1-24 @ 13:45
image is not available :(
User avatar
oeuvre
Postby bjwil1991 » 2019-1-24 @ 14:40
Imgur has mods running the clock 24/7 looking for anything that's lewd.
Systems from C64 to FX-6300.
User avatar
bjwil1991
Postby NuuttiS » 2019-1-24 @ 19:56
badmojo wrote:That is indeed an awesome case, love the 90's pastel green power button. Also points gained for the period correct mitsumi CD drive.
Anyway cool system.
I'm really happy I found that case. Yes that power button color is really 90's! That quad speed CD drive might be the only thing I had left from my original system from 90's. I guess you can't save everything..
U7 runs too fast. I haven't yet tried how it runs with turbo off, but before this case I disabled caches and set cpu speed low from BIOS and it worked fine. I haven't found info what that cpu setting actually does - does it really lower clock rate or add wait-states like turbo button.
SSHOCK is definitely playable with max detail and full screen. I'd guess it runs about 20fps and drops a bit when there's a lot going on.
NuuttiS
Postby appiah4 » 2019-1-24 @ 21:20
DX2-66 too fast for U7? Isn't it supposed to run perfectly on DX2-50? Or was that Pt.2? I forget..
A500:+512K|ACA500+|C1084S
i386:Am386SX-25|4M|TVGA9000B|ES688
i486:U5S-33|8M|GD5428|CT2290/MUNT-Pi
i586:P133|32M|S3T64+/MX2|V1|CT3980/32M
i686:K6-2/400|64M|V2/SLI|CT4500/32M
S370:P3-1200|384M|GF4Ti4200|MX300
S754:A3700+|2G|X1950PRO|SB0350
User avatar
appiah4
Postby NuuttiS » 2019-1-24 @ 22:09
appiah4 wrote:DX2-66 too fast for U7? Isn't it supposed to run perfectly on DX2-50? Or was that Pt.2? I forget..
Yes, the characters move like chipmunks on speed. A bit strange as U7 and DX2-66 were released both 92 if I remember right.
NuuttiS
Postby johncasey » 2019-1-26 @ 10:06
Hello there!
I really enjoy this forum and got great advice from here.
I'm trying to build a miniature 486 dx4 100, without fans. I love the biscuit pc industrial mainboards from advantech, because they are very small and you can find them easily on ebay.
So far, I have built this one, with:
- a pcm1823 mainboard boasting a dx4-s cpu, vga and 10mbps ethernet!!!!
- a 16 mb memory stick
- a 2gb transcend 44pin ide flash drive
- a sweet opl3lpt or a cvx4 depending on the mood of the day
- a poor man's case built with two pieces of acrylic, 8 small tubes and 4 screws & bolts.
- a 5v3a ext. psu
I like it a lot so here it is:
my jan2019 dx4
I've just bought this sound card from ebay:
diamond crystal ess based soundcard
I plan to improve my setup with this ess based pc104 soundcard. I might get better compatibility. Can't wait to receive it!!!
But I really LOVE my cvx4 and opl3lpt!!
johncasey
Postby JustDavid » 2019-1-26 @ 14:39
My EZ-Buddie 1 with a Pentium 4@2.5ghz, 160gb HDD, 1GB Ram and a Radeon 9250.
The tiny little tower has a backlit Display in front and even lets you adjust CPU clock with a little dial.
Looks lovely in a dark room!
JustDavid
Postby gdjacobs » 2019-1-26 @ 20:50
That looks awesome! Does the board support de-turbo?
User avatar
gdjacobs
Postby clueless1 » 2019-1-26 @ 21:23
33-40Mhz on a 486 is perfect. Any faster and the world speeds up comically. De-turbo should work nicely. On my DX2-66, the system would run the equivalent of about 20Mhz when de-turboed, which worked out quite nice on U7.
User avatar
clueless1
Postby oeuvre » 2019-1-27 @ 00:01
mmm format C:
User avatar
oeuvre
Postby appiah4 » 2019-1-28 @ 10:48
How would a DX33/40 do in Ultima VII Pt. 2? I guess U5SX 486-33 is probably a sweet spot CPU for both games?
User avatar
appiah4
Postby tayyare » 2019-1-28 @ 13:22
oeuvre wrote:mmm format C:
Do you format your hard drive every 6 months?
:blush: :lol:
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
User avatar
tayyare
PreviousNext
Return to System Specs
Who is online
Users browsing this forum: No registered users and 3 guests
