Reply 10980 of 31856, by PC Hoarder Patrol
Sort of retro - a few weeks ago I posted a shot of some old software floppies that had belonged to a relative, and after a bit of discussion we agreed a deal that as they no longer have either the health nor the interest to retain any of this old material that it would be better if I took it all off their hands, which I've now done.
I wouldn't exactly call it a collection as such; more a very modest accumulation of items (hardware & software) that they've used over the last 30 years. I'll post up some pics as I sort thru it all.
Reply 10981 of 31856, by oeuvre
Tossed in a CT4170 in the DTK
Reply 10982 of 31856, by henryVK
Ugh... there's a Compaq Portable available here that I really want, but it's 180 yuros...
Maybe I'll see how low they'll go *_*
Reply 10983 of 31856, by jaZz_KCS
There's a Compaq Portable III (with what seems to be quite close to original hardware it came with back in 87/88 here on German Shpock and Kleinanzeigen as well. Seems expensive but then again, these don't get any more common these days.
Reply 10984 of 31856, by JustDavid
I installed 98SE2ME on my 98SE installation with service pack 3! ; )
Reply 10985 of 31856, by Windows9566
voodoo5_6k wrote:
appiah4 wrote:
Installed a backplate on my K6-2 system, thanks to liqmat for being so generous with this part. I thought this PC would never have a backplate, but it actually does now..
With patience, time and a great community like Vogons, anything is possible I guess!
These can be found relatively easy, as many motherboards used this I/O layout. I have two of these motherboards, Asus P/I-XP55T2P4 and Intel Advanced/ML (Marl). One valid part# for this type of I/O shield is 32140544A (just in case anybody else is looking for one...).
The Intel Performance/AU, Tyan Titan, etc. had that port layout too.
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
Reply 10986 of 31856, by _ar
Hey Guys,
I'm new to this board and happy that I can be a member!
Today just placed an order for an AM27C400 adapter for my TL866II+ EPROM programmer and a KS ROM adapter for my Rev5 Amiga 500 boards. Yesterday, I kind of fixed an internal A500 floppy drive, but it still needs recapping and probably trace repair which I'm hoping to solve the disk change sensing issue it has.
Reply 10987 of 31856, by Turbo ->
_ar wrote:
Hey Guys,
Welcome to Vogons forum 😀
Reply 10988 of 31856, by Almoststew1990
This is probably the most tenuous link to, as well as most boring example of, "retro activity". When I build and troubleshoot my retro PCs, they get taken out from their under desk home and slide onto my desk. This chips and scratches the black coating on my cheap and nasty desk. For some reason I chose a black desk, which shows up dust and scratches as if it's its only mission in life. So, today I filled it in with permanent black pen (yes, my weekends are very exciting, thanks 😜)
Now to try to ink one of my yellow CD drive face plates black so I can use it in a black case...
Reply 10989 of 31856, by oeuvre
Those "service packs" always end up causing problems. In the future, try to avoid using them. You'll see what I mean soon.
Reply 10990 of 31856, by JustDavid
In my process of turning a Pentium 4 PC into a DOS/win9x gaming machine i have found out about a lot of interesting stuff!
There is lots you can do with Windows 98SE that i was never aware of.
The OS has quite a few limitations when it comes to maximum storage and RAM, as well as issues with very fast CPUs, but all of those can be fixed.
There is something called "Unofficial Service Pack 3" for 98SE which comes with a lot of updated programs, hotfixes and major improvements for the OS!
Installing that was a breeze.
After that i installed something called "98SE2ME" which turns your 98SE installation into a Frankenstein-system that has all the stability and compatability of 98SE, but the better performance and options of Windows ME without any of ME's instability.
also... archive.org hosts lots of Images of old Windows OS-versions legally and completely free! 😲
Reply 10991 of 31856, by Predator99
Did a wet cleaning on this one:
The attachment IMG_0855r.jpg is no longer available
Now it looks much better but still some repairs to be done.
The attachment r.jpg is no longer available
Its labeled "3COM ASSY 2012-01". It seems to be "3C505" (thanks dionb!).
Most beautiful Ethernet card I own so far. With a 80186 CPU. Will try to find drivers and get it running.
Let me know somebody is interested in this, will open a new topic then...
Reply 10992 of 31856, by ultra_code
JustDavid wrote:
In my process of turning a Pentium 4 PC into a DOS/win9x gaming machine i have found out about a lot of interesting stuff! There […]
Well, I have no experience with the unofficial SP3 for Win98SE, but I have avoided it for such concerns
If it ain't broke, don't fix it. 😜 Besides, I believe that SP3 essentially makes IE unusable, which now is a bit more of a concern since I have set up an FTP NAS in my home, and the easiest way to access that data under 98 (if I wanted to) is with IE6, so I rather not make life harder for myself.
In regards to memory, I'm sure I'm correct in saying this (someone could back me up), but like 99% of all Win98 programs don't need more than 512MB of RAM, and if you want more RAM in your system for, say, a Win98/XP dual-boot setup, but don't want to make your 98 install unable to boot because 98 is stupid and doesn't know what 2GB of RAM is, then use HiMemX, a memory manager that allows you to limit the amount of RAM Win98 sees without altering any part of your Win98 instal. Simply download the executable, throw it somewhere in your Win98 install, (for example, in the C:\WINDOWS directory), and then add the following line into your config.sys file:
DEVICE=C:\WINDOWS\HIMEMX.EXE /MAX=524288
^ Amount of RAM in kilobytes you want Win98 to see.
Also, if you want universal USB flash drive support, get nusb36e.exe (you can find multiple download sources here) and install it under 98. All it does is it takes some of that USB functionality from WinME and adds it to 98.
Never heard of that update. Again, though, who knows what that does under the hood.
Builds
Reply 10993 of 31856, by SpectriaForce
I have replaced a few capacitors on my Elitegroup P5HX-B socket 7 baby AT motherboard. It had some capacitors of the brand Chhsi near the AT PSU connectors and CPU voltage regulators. Interestingly it also has a high quality Oscon elco near the CPU socket that looks original (that I haven’t replaced). I have also replaced the Dallas clock battery which sits in a socket on this board. The ‘new’ Dallas clock battery from a French ebay seller seems to be manufactured in the same year as the old one.. 😐 I wonder whether it works..
Besides I’ve tried to rescue a nice high quality socket 5 Intel motherboard, but the CPU socket lock tab is damaged (thanks to whoever did that) and it has a soldered Dallas battery that I can’t remove with my soldering iron, so that one is EOL. A shame for what should have been a bargain (cost me € 20). At least I was able to save a Pentium 90 and three SIMM’s.
Reply 10994 of 31856, by _ar
Cleaned off rust from a C=Plus/4 modulator box.
Cleaned off battery acid residue from my ABIT AH4 motherboard. Cleaning will continue once I desolder the battery and will see how many traces I need to repair. Regarding this modo @brostenen, do you still have your AH4T?
Reply 10995 of 31856, by brostenen
Shure.... It is happy serving me as my Dx2-80 VLB-S3 and VLB-SCSI. 😜 Wonderfull board.
Reply 10996 of 31856, by _ar
Awesome! May I ask for a some help in this topic Have an ABIT AH4T? Please help me out!?
Sorry for the OT!
Reply 10997 of 31856, by oeuvre
Also upgraded the DTK from 16MB RAM to 64MB and tossed in a 3COM 3C905B-TX ethernet card.
Reply 10998 of 31856, by bjwil1991
I installed my 80GB Western Digital HDD (new) in my Windows 98SE machine and changed the board from the Socket 423 to Socket 370 again since the PSU has issues with 2 HDDs, 2 ODDs, 1 FDD, and the IR Driver for my SB Live! 5.1 sound card. Is there a way to force the fixed disk to a different drive letter other than D? Some of my PC games require the CD-ROM to be set to drive D and not E-Z.
Partitions per HDD:
Maxtor 60GB: Primary (C:)
Western Digital 80GB: Logical/Extended (D:) --> assign to (F:)
Optical drive:
LG CD-RW (E:) --> should stay at (D:)
Samsung DVD-ROM (F:) --> should stay at (E:)
Reply 10999 of 31856, by liqmat
bjwil1991 wrote:
I installed my 80GB Western Digital HDD (new) in my Windows 98SE machine and changed the board from the Socket 423 to Socket 370 […]
Partitions per HDD:
Optical drive:
Re: Need help with Windows 98se and drive letters
