First post, by Thraka
- Member
I'm splitting this from my other thread about multiplayer beacuse I listed both issues but noone has commented on the scaler issue 😀
So even HW scaling has no effect, it always plays the same size no matter what. I can easly change the settings around, load something like Wing commander, and you can see the scalers take effect. I quit the game go load Global Conquest, and it still doesn't effect the game!
So I did a bit more investigation and I find that turning off ALL scalers and loading a normal game, makes the window VERY small. I load GC and it's still the same size as the dosbox window. It's like it uses it's own resolution model and scalers dont take effect.
So with or without aspect correction turned on the size of the window no matter the scaler in effect, is:
false: Bottom of the window is brought up a little bit, rest is same size
true: Window is not changed at all, game uses it all.
