zerodiagonal wrote:The mouse from the left has a semi-glossy finish already but I agree the scratches are more noticeable because they're pretty dirty. Use a toothbrush and warm water+soap (or a soaked cloth) and give it a go. Probably retrobright them before (I'´'m in the process of doing the same for my serial mice(sp?)).
Thin scuffs can easily be removed with brass metal polish and some patience. Silver metal polish is ok'ish for glossy surfaces like plastic displays from vcr, stereo and stuff . They'll fog the area a bit so consider that beforehand. I've managed to fully recover unreadable cd/dvd discs this way, if patience (some discs can take 20+ minutes easily) it'll give better results than any of those spinning things (skip doctor-like).
What's the best time to Retrobrite, I'm thinking of removing the top from my Mouse Port Compatible Mouse (which is next to the Serial-PS/2 Mouse) and putting it in a clear container full of hydrogen peroxide, it's the best shape out of all the Microsoft mice, despite the logo wearing off, there's barely any scratches on it. I have used Peroxide for retrobriting keycaps and other small things, i use the salon creme/plastic wrap for bigger things like the front panel of my ATX case, the keyboard's shell, etc. and btw, the Serial-PS/2 Mouse is not really that yellowed, it's cause of the yellowish light from the light bulbs that i have, i wish i found white LED bulbs but too bad Walmart doesn't have them
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
