First post, by Intel486dx33
I am trying to install Win311 but It stops working at detecting network card ?
Is there anyway to disable network card seek during setup ?
I know there is "Setup /F" which forces the seek of netowrk card but is there any switch to install Win311 without network card seek ?
I am using a 486 motherboard with 3 PCI slots and 4 ISA slots, ALI chipset ( American Megatrends Bios 1993 )
I only have PCI network cards at the moment. I have 3com 3C509b, and AMD chipset, and Netgear FA310tx network cards.
The AMD usually work with Win-NT-3.5.1 and they all work with Win95c.
I usually don't have any problems with the AMD network cards.
So I install Win311 with "Setup" command.
Go threw the menu setup process okay and then then files are copies a NEW screen appear where setup try to detect Network card.
But this is where the setup hangs and I can't get past this step.
If I remove the network card will setup skip the network card detection process ?
Are PCI cards supported in Win311 setup ?
All my hardware and computer works because I already tried it with Win95c and everything works.
