First post, by NostalgicAslinger
My Athlon Slot A dream system is finally done!
AMD Athlon 1000 Thunderbird Slot A 1,75V@1,60V undervolted, new Thermal compound and 2x 50 mm new Revoltec fans
Asus K7V-T VIA KX133
512MB Kingston PC133 CL2/2/2
3dfx Voodoo4 4500 AGP with a small copper heatsink on the backside of the VSA-100 chip
Aureal Vortex 2 PCI
VIA USB 2.0 PCI card
Maxtor DiamondMax Plus 8 40 GB IDE
3,5" Floppy
LG GSA-H10N DVD Writer
Delta Electronic 350W Power Supply
Chieftec Bravo BM-01B case
Windows 98 SE with Update Pack 2.1e
279.32 KiB
1.53 MiB
1.58 MiB
1.75 MiB
270.12 KiB
Reply 1 of 14, by doaks80
What on earth is the heatsink behind the voodoo core?
k6-3+ 400 / s3 virge DX+voodoo1 / awe32(32mb)
via c3 866 / s3 savage4+voodoo2 sli / audigy1+awe64(8mb)
athlon xp 3200+ / voodoo5 5500 / diamond mx300
pentium4 3400 / geforce fx5950U / audigy2 ZS
core2duo E8500 / radeon HD5850 / x-fi titanium
Reply 2 of 14, by NostalgicAslinger
Small copper heatsink for the backside of the VSA-100 chip, fit 100%. Better cooling and longer life. The card also works fine with 183MHz, higher not tested and I do not want to do it.
Reply 3 of 14, by doaks80
Yeah i get that, i do the same thing....i mean the long copper strands....where did you get one like that?
Reply 5 of 14, by doaks80
Damn...wish I knew about them before I sinked up my V5...not cheap but I guess they are worth it.
Reply 6 of 14, by rasz_pl
KX133 chipset supports SDRAM Bank Interleaving, has potential to work a little faster with two modules.
https://forums.anandtech.com/threads/kx133-kt … y-tweak.423179/
worked great on KT133, but I seem to remember problems on slot A platforms at the time.
Reply 7 of 14, by NostalgicAslinger
Yes, I know, 4 way is activated in the bios and also wpcredit says, that this feature is active. Runs without any problems.
I am using this 512MB high quality memory stick. Also does 150MHz with the best timings! The Asus K7V-T is also one of the fastest VIA KX133 Mainboards. Faster than the Epox 7KXA, that I have used before.
481.25 KiB
Reply 8 of 14, by Almoststew1990
Nice. I do like a good Slot 1 Athlon system, I have a pluto 800MHz, Thunderbird 700MHz and somehow seem to have collected quite a few 500/550 MHz too...
For some reason I can't get my Irongate motherboard to work with the Thunderbird CPU (despite being on the latest BIOS). These boards were some of the few that would support Slot 1 Tbirds 🙁
Reply 9 of 14, by NostalgicAslinger
The K7V-T is the only KX133 mainboard with official Thunderbird CPU support. My Epox 7KXA KX133 works with T-Bird CPUs, but with max. 800MHz. There was never a official T-Bird CPU support for the KX133 chipset, but most of the boards will work with this core, but with max. ~800MHz. A Orion 1Ghz always works.
With a 1 GHz T-Bird you need luck to find one, I had problems with the Epox, here is a thread, that's why I have changed the mainboard: AMD Athlon Thunderbird 1000 MHz Slot A and Epox 7KXA Rev. 0.4 VIA KX133 stability problems
Reply 10 of 14, by rasz_pl
does it make a difference with only one module? I always assumed it needed a pair
EDIT: doh, its right in the name, bank interleaving, it works with one module 😀 /slaps himself
Reply 12 of 14, by melbar
Be careful to the small capacitor between the cpu-cooler and the ram sockets, directly under the fan header.
It is looking even worse than the other's what i can see on your pictures.
It's worth to replace it. 😉
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 13 of 14, by cyclone3d
Very nice. I've never seen a 1Ghz Slot A T-Bird in person though I do have a couple 900Mhz ones that I rescued from being thrown out over 10 years ago.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 14 of 14, by NostalgicAslinger
Ok, one capasitor looks like he has a bumb on the pictures, but looks ok. Only a optical Ilusion. Here is a better picture of the mainboard. Made a few days earlier, before I changed the Epox 7KXA in the case.
1.97 MiB
The 900 MHz version should easy do 1GHz with a Goldfinger Device. 😀
