First post, by appiah4
- l33t++
Do 100MHz Athlons with higher amount of cace have any significant performance advantage over Durons with higher clockspeed? Does the Duron having SSE make a meaningful difference with regard to software or OS it can run? Which one between an Athlon 1000 and a Duron 1300 is the better CPU for a KT133 system without taking overclocking into account?
