First post, by Old PC Hunter
I am curious as to how much power this computer consumes.
It has:
AMD 80286 6/8 processor
Unknown mobo, says 202286-002 on it
Maxlogic MX 677 VGA card
One NEC 5 1/4 inch floppy drive
One SONY 3 1/2 inch floppy drive
One Acculogic sIDEBoard
I'm pretty sure the power it consumes is not much, i'm just curious.
Set up retro boxes:
DOS:286 10 MHZ/ET4000AX1MB/270 MB HDD/4 MB RAM/Adlib/80287 XL
W98:P2 450/Radeon 7000 64 MB/23 GB HDD/SB 16 clone/384 MB RAM
XP:ATHLON X2 6000+/2 GB RAM/Radeon X1900XTX/2x120 GB SSD/1x160 GB and 1x250 GB 7.2k HDD's/ECS A740 GM-M/SB X-Fi
Reply 2 of 10, by Old PC Hunter
Hmm...
I wonder how many watts my PSU puts out. I cannot find any indicator as to how much wattage it has. It's a S2 API 8138 PSU.
Set up retro boxes:
Reply 4 of 10, by Old PC Hunter
I'm sure you didn't find out how much watts that thing outputs though?
Set up retro boxes:
Reply 6 of 10, by Old PC Hunter
I see the rails, but I do not see the approximate wattage number. Did you just convert the amps on the rails to watts and add the watts or did you look on the PSU label and find 100W? If you found 100w on the psu label please take a picture of it's location.
Set up retro boxes:
Reply 7 of 10, by Old PC Hunter
Set up retro boxes:
Reply 8 of 10, by alvaro84
Well, I just measured my 286. I give that it's not yours so the result won't be the same but it still says something. It idles at ~29W and consumes up to 37.5W while spinning up the hard drive. The config is as follows:
Octek Fox II 286 board (very small, heavily integrated Headland chipset) with a Harris 20MHz CPU
4MiB SIMM RAM
Cirrus Logic GD-5402 512kB VGA
Gravis Ultrasound Classic 3.74 (I know it's crazy but there are a few games and demos that can use it in a 286 😁)
ES688 for real OPL3 music and SB compatibility (yes, it has the Yamaha chip)
Standard ISA I/O card (probably Winbond based)
1.2M+1.44M FDD
840MB Quantum HDD
HP PS/2 keyboard
The power supply is a rather modern (for an AT PSU) 200-watt DTK piece. The other parts are relatively recent too and probably consume less power than old bulky hardware with a hundred logic chips on the mobo and the cards and an oldschool hot 286 (the 20MHz Harris CPU is definitely much cooler than, say, a 10MHz Intel one) yet I wouldn't think a more oldschool 286 could draw more than ~1.5x of this config. The only way to seriously outdo it would be a huge MFM hard drive. What does that sideboard do btw?
On a side note, the original IBM PC power supply was rated for 63 Watts and AFAIK it could cause problems with a combo of expansion boards and MFM drives.
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
Reply 10 of 10, by Old PC Hunter
Sorry I sent so many messages, Vogons wasn't letting me post anything, but thanks for all the info. Also, alvaro84, your 286 seems like a very good system. 😀 I think I will use your build as inspiration for what i'm going to do with my 286. The sIDE Board is an IDE hard disk controller and i/o controller, but the board already has these functionalites, so i'll be removing it soon.
Set up retro boxes:
