First post, by RiP
Hiya all,
Is it possible to upgrade the VRAM of my Trident 9000i from 512KB to 1MB? 😕
Reply 2 of 10, by Anonymous Coward
512kb actually isn't too bad. You can do up to 800x600 in 256 colours, so it's fine for stuff like Windows 3.x.
Reply 3 of 10, by RiP
Thanks all =)
Reply 5 of 10, by Grzyb
foxbat wrote on Yesterday, 22:27:
Are you sure? I have TVGA9000i 512kB and couldn't get more than 800x600 16 colours. The manual says same: https://www.minuszerodegrees.net/manual ... Rev. B.pdf ???
Let me guess: that card has 100 ns RAM chips, right?
For 800 x 600 x 256 you need 80 ns RAM.
Nie rzucim ziemi, skąd nasz root!
Reply 6 of 10, by darry
Grzyb wrote on Yesterday, 23:04:
The card in OP's first post has 80ns DRAM, if I am not mistaken.
The manual linked here is indeed likely from a card with 100ns DRAM.
And your guess is probably quite accurate
The attachment Screenshot_20250915-211038-569.png is no longer available
Source: datasheet from here : https://www.vgamuseum.info/index.php/cpu/item … ident-tvga9000i
EDIT: By the way, the TVGA9000i is quite slow, AFAICR, and as you already know and hopefully OP also knows.
Reply 7 of 10, by st31276a
My 9000i has two types of ram chips on it. Two are normal dip and the other two are funny upright ones, they look like oversized resistor strips with square corners.
One kind is 80ns and the other 100ns. I cannot remember which is which, but I think the funny upright ones are 100ns.
I have this one since new, I "upgraded" to it back in the day to get 256 colours in windows 95. Was the cheapest and didn't know any better back then.
This specific specimen can run 800x600 in 256 colours, but it looks like crap and the screen shimmers. 640x480x256 is fine though. Thought it was the monitor back then (only used to run 640x480 up until I got the card) but now I know the card also had a healthy contribution to the situation.
Watching it paint the screen is quite painful.
Rather go for a 8900D, it is double the speed.
Reply 8 of 10, by AlexZ
I used to play Transport Tycoon on 386DX40 with Trident 9000i with ISA bus OCed to 12 Mhz to make it faster. On 386, 800x600 isn't usable for anything else than viewing static pictures as it's too slow. Giving it 1MB VRAM wouldn't improve it much.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Athlon 64 3400+,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2 ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 9 of 10, by st31276a
AlexZ wrote on Today, 09:53:
I'd venture to say it might even make it worse, as it would invite you to try out things that would end up tasting like disappointment.
Reply 10 of 10, by dionb
That datasheet makes no mention of VRAM and is quite explicit about DRAM. I doubt VRAM would even work, regardless of quantity or speed, and generally VRAM actually has lower DOS performance compared to DRAM on the same chipset. OCing the ISA bus might make more sense and upgrading the 100ns DRAM to 80ns; that would enable non-interlaced modes at other resolutions. But the card would remain a complete slug whatever you do to it.
