First post, by dkarguth
I have no prior experience with Slot 1 boards or CPUs, so can anyone tell me if this motherboard and processor are decent?
I found this motherboard for $7 at the local Goodwill brand new in box. I have had a Pentium II sitting on my shelf as a random decoration for 5+ years now, so I thought what the heck, I could build a Slot 1 machine. I noticed that it is a dual slot motherboard, will this cause any problems using it with only one processor? Also, if I wanted to use a Xeon in it, could I run a dual processor setup with a Xeon and a Pentium II? Like I said, I have no knowledge about Slot 1 boards, and I have never owned a dual processor board before. Is there anything crucial that I should know about Slot 1 motherboards before I start screwing around with it? I don't want to mess anything up or end up wasting hours on some silly common problem. I already spent an embarrassingly long time trying to remove the processor from the slot until I figured out it has latches...
Also, what would be the optimal OS to use with the machine? I thought about setting up NT4 or Windows 2000 to use it as a local webserver/file server just for kicks and giggles, but I'm not to sure how well it would run either of those.
Here's the motherboard:
Here is the Pentium II that I plan to use with it
"And remember, this fix is only temporary, unless it works." -Red Green
