First post, by dipi25
I'm using DosBox 0.63, and want to play C&C (Win95 Version).
The Processor is an AMD Sempron Mobile(754=desktop) 2800+
RAM 512MB 128MBshared 4 graficchip
The mosteproblemkind of M$ Windows XP Pro (I have installed it 120 times @home !)
If I'm running the setup.exe file are promt in Dosbox win setup.exe
If I'm running the install.exe file are promt in Dosbox win install.exe
If I type setup -cdCD nothing perhaps!
If I type install -cdCD nothing perhaps!
The drives I have mounted 😁 but in the installation of Win98 the computer says: The installation can only run on mashine with over than 66MHz. I have min. 1533! (Benchmark tested!)
Must I upper this line "cycles=7500" to "cycles=75000" 😕
I don't want to backing my CPU...
C-Ya
-dp-
25-jears jung 😀
lived in germany
