First post, by muon
Hi! I need change some defective memory chips in a 486 motherboard:
What type of socket using the memory of previously picture: DIP-28 or SOJ?
Are the sockets in the links OK?
https://es.aliexpress.com/store/product/10PCS … bd-0d8cd278e376
https://es.aliexpress.com/store/product/10PCS … 67-93ef617c0e81
https://es.aliexpress.com/store/product/10-pc … 67-93ef617c0e81
Reply 1 of 4, by konc
Those are definitely DIP chips.
SOJ look like this
The attachment soj.jpg is no longer available
Reply 2 of 4, by ph4nt0m
These are DIP-28. All 256Kbit (32Kx8) SRAM chips are 28-pin. 512Kbit and 1Mbit are 32-pin.
What makes you think your chips are defective?
My Active Sales on CPU-World
Reply 3 of 4, by quicknick
They seem to be soldered, so most probably fakes.
Reply 4 of 4, by Deksor
Yeah they're not defective, they just never worked because it's a fucking piece of metal inside a plastic shell with metal legs ^^
But I noticed that on most boards (except the infamous pcchips m919), replacing fake cache chips solves the issue, no need to modify the bios, and the traces actually go somewhere (unlike on the m919) so it should work. However you should also put proper jumpers in the spots where they should be. Currently they're hardwired.
