First post, by tensi0n
Hello,
I have a Pentium 2 MMX 266MHZ machine with 32MB ram. The video card is an S3 Virge and it has a fresh installed of windows 95 on it. For whatever reason, I'm getting these weird artifacts on the screen after I open and close new windows and/or programs. Eventually the computer will lock up and I have to do a hard shutdown. I've tried a few different video cards as well as put them in differnt PCI slots and I am getting the same results. Any ideas what could be causing this? Thank you. I attached a couple photos.
Reply 1 of 13, by DankEngihn
Potentially a bad RAM stick? Try booting the system with only one stick of known-working RAM, and see if the issue still occurs.
Reply 3 of 13, by tensi0n
rasz_pl wrote:
bad graphic card, bad driver, something wrong with pci controller/slot
So the graphics cards I’ve used all work great in other machines. I haven’t swapped out the ram sticks yet so I’ll try that. Maybe the contacts and/or PCI ports need to be cleaned out. The MB I’m using was pretty filthy when I received it. I sprayed a lot of the dirt off with compressed air but maybe it needs more of a deep cleaning. Could dirt and grime cause an issue like this? Other than the issue I’ve stated, everything seems to boot up and run fine.
Reply 4 of 13, by Ozzuneoj
That's an odd one. I've seen things like that caused by a bad video card, but if it does it with multiple cards, I'm not sure.
Check for swollen or leaky capacitors on the motherboard.
Try a different power supply too.
Reply 5 of 13, by tensi0n
You know now that you mentioned it, my power supply has been making a funny noise off and on. It makes a low buzzing noise but it’s not constant. I didn’t think anything of it because the system seemed to be getting enough power. The power supply is about 10 years old. Once I get home from work I’ll see if the power supply is the issue.
Reply 6 of 13, by tensi0n
Well after swapping out different power supplies, video cards, memory, HDD, and trying w95 and w98 (just to see), I still get the same issues with the artifacts and freezing. I'm thinking it is a problem with the motherboard. I have no idea what would be causing this on the motherboard itself. I don't see any obvious capacitors bulging or any other weird things going on with the circuitry. Any ideas out there?
The motherboard I am using is a Supermicro P6SKE II. It's a shame because I love the bios menu it has and I wanted to have a working P2 machine with win95.
Reply 7 of 13, by rasz_pl
corrupted pci transfer, have you tried different pci ports?
Reply 8 of 13, by Windows9566
Things you will never own, but want to.
on a older vogons thread about (Things you will never own, but want to.) theres a post about that similar super micro 440fx board. that guy said that Unfortunately both revisions have wonky PCI that causes font and mouse cursor corruption with most graphics cards. S3 PCI chips actually lock up almost instantly once the drivers are installed.
R5 7600X, 32 GB RAM, RTX 3060 TI, Win11
P3 750, 384 MB RAM, Matrox G400, Sound Blaster 32, Win98
PMMX 166, 64 MB RAM, S3 Virge DX, Aztech AZT2316R, Win95
486DX2 66, 32 MB RAM, Cirrus Logic GD5430, Aztech AZT2316, DOS
Reply 9 of 13, by tensi0n
Yes I’ve tried every single PCI port with same issue. Is a corrupted PCI transfer fixable?
Reply 10 of 13, by tensi0n
Well that’s probably my problem 🤣. Both cards I’ve tested with this machine are S3 cards.
Reply 11 of 13, by tensi0n
UPDATE:
I was able to dig up a Matrox 703 graphics card and installed it in my machine. The issues I've been having went away so it appears the S3 cards where the issue. The problem is now I can't find actual drivers for the card so I am running it with the standard VGA drivers from win95. Does anyone know where I can find the drivers for this? I created a new post reference my driver question: Matrox 703 Graphics Card
Thanks.
Reply 13 of 13, by Ozzuneoj
rasz_pl wrote:
no driver installed = you cant be sure its working
Right, the vast majority of graphical problems will only show up when drivers are installed.
