First post, by Imperious
I didn't know this could be done until tonight, but about 2 years ago I bought an AT computer with an Epox Super socket 7 motherboard inside, and later
found out that the cpu socket locking latch was broken. I've managed to fix it with a donor motherboard that had a socket 5 on it, the latch is the same.
It's actually quite easy to separate the 2 parts. A 10mm wide flat blade screwdriver fits under the back and lifts it up a bit, not too much pressure, then
insert another similar tool into the left back notch, jiggle it a bit and it should release, then the rest can be easily released and the top removed.
Due to the location of caps, etc, other motherboards may require a modified approach.
