First post, by feipoa
- l33t++
Is there anyway to get the POD133 for the socket 4 platform to run at 1.5x? I remember reading somewhere that some POD units will run at a lower multiplier if the integrated fan is removed. I tried to run my POD133 without a fan at boot, but the system wouldn't turn on. If I remove the fan after boot, the system still runs, but chkcpu indicates that it is still running at 133 MHz, or 2x.
