First post, by w0lf42
- Newbie
I'm having a strange video issue in DOS. After a random interval of being in DOS, the screen loses some pixels. If I load something that changes the resolution (e.g. Doom), everything is fine.
For testing purposes, I have a DOS CD audio program installed, SJGPLAY. This program triggers the issue very quickly.
Here is a screenshot that I took with Snarf while the issue was happening. Everything looks fine:
I took a picture with my phone of the same screen:
I've only seen this happen with the following combinations:
- Resolution: 700x400@70Hz
- Cable: VGA
- Motherboard: Either
- Video Card: Either
- Monitor: Either
I've tested with the following resolutions (I'm using the on-screen menu of my monitor to tell me what resolution it's using):
- 700x400@70Hz
- 1280x1024@60Hz
I've tested with the following cables:
- VGA
- DVI
I've tested with the following video cards:
- NVIDIA GeForce 2 DDR Ultra 64MB AGP with DVI and VGA
- NVIDIA Quadro2 Pro 64MB AGP DVI and VGA
I've tested with the following motherboards:
- DFI CA64
- ASUS CUV4X-E
I've tested with the following monitors:
- Dell P1914S 19-inch (1280 x 1024)
- Dell Ultrasharp 1909wb 19-inch (1440 x 900)
