Bug?
First post, by Wallace
I have the "autoexec" section set up thusly:
[autoexec]
set path=c:\;c:\Norton\
mount a: c:\emulators\dos\
mount b: f:\ -t cdrom
mount c: c:\emulators\dos\
mount d: d:\games\
mount e: e:\ -t cdrom
mount f: f:\ -t cdrom
mount g: g:\data\
c:
cd Norton
nc.com
cd \
...and unless I remove the path line, Dosbox will always crush when shutting down.
Reply 1 of 4, by Kippesoep
I'm not sure about this, but have you tried moving the path line to after the mount lines? The given paths don't exist before the mount lines...
My site: Ramblings on mostly tech stuff.
Reply 2 of 4, by wd
Rank DOSBox Author
DOSBox Author
And try
mount a c:\emulators\dos\
instead of
and so on (remove the first : )
Reply 3 of 4, by Harekiet
Rank DOSBox Author
DOSBox Author
the dosbox shell also likes having z:\ in it's shell to actually find the mount program 😀
Reply 4 of 4, by eL_PuSHeR
Would this work?
mount b f:\ -t cdrom
mount c c:\emulators\dos\
mount d d:\games\
mount e e:\ -t cdrom
mount f f:\ -t cdrom
mount g g:\data\
set path=%path%;Z:\;c:\;c:\Norton\
c:
cd Norton
nc.com
cd \
One remark: Normally A and B letters are reserved for floppy drives.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
