First post, by ph4nt0m
I've recently acquired a large variety of computer hardware from local scrappers. Many of them have missing parts unfortunately. There is a Rendition Verite V2200 8Mb AGP card made by Super Grace probably.
http://www.vgamuseum.info/images/palcal/rendi … 6g-2_top_hq.jpg
http://www.vgamuseum.info/images/palcal/rendi … 2_bottom_hq.jpg
My one has NEC D481850GF-A10 SDRAM chips instead. However it's missing a BIOS chip. Could anyone dump a BIOS of any V2200 AGP card and upload it here?
My Active Sales on CPU-World
Reply 1 of 12, by Ozzuneoj
Nice find! The V2200 is quite uncommon.
And aren't scrappers savages? I've had a lot of really nice old hardware come to me with missing back plates and BIOS chips lately. Really rare and useful stuff that has been stripped of parts that I wouldn't be able to fabricate even if I had the tools. Geforce 256, Geforce 3, Nvidia NV1, SB Pro CT1330A and much much more... all stripped of random parts. For what? They got way more for them selling them to me than to scrappers (that's how I got them). If they did a little research for "collectible old computer parts" they'd know this...
... savages I tell you!
Hopefully someone here has the BIOS for you.
I really think we need to put together a card BIOS repository. And while we're at it, we need to figure out a way to standardize the measuring of card back plates so we can fabricate replacements for cards with strange layouts.
Reply 2 of 12, by swaaye
How about a Hercules Thriller3D BIOS? The readme says it's for AGP and PCI cards. 4MB and 8MB variants.
http://www.vogonsdrivers.com/getfile.php?file … &menustate=17,1
                       Hercules Thriller 3D BIOS
Version 1.04.141
Installation Guide
April 2nd, 1998
This archive contains flash BIOS utilities for the Hercules Thriller 3D (4MB). The following
files are included in this archive:
DOS4GW.EXE : DOS Extender (used by the flash utility program).
FT141_4.EXE : BIOS flash utility, version 1.04.141 for 4MB PCI or AGP Thriller 3Ds. Use
this flash program with models TH2204 and TH2304A.
README.TXT : This file.
I don't have an actual AGP V2x00 card to dump and I'm not sure what utility would do it...
Reply 3 of 12, by VooDooMan
Here you go:
https://www.sendspace.com/file/ao884f
Best Tualatin Motherboard
ECS P6S5AT at 166 MHz
Overclocking Pentium III
Reply 4 of 12, by ph4nt0m
VooDooMan wrote:
Here you go:
It redirects to http://www.servscience.com which cannot be DNS resolved.
Reply 5 of 12, by ph4nt0m
swaaye wrote:
How about a Hercules Thriller3D BIOS? The readme says it's for AGP and PCI cards. 4MB and 8MB variants. http://www.vogonsdri […]
Version 1.04.141
Installation Guide
April 2nd, 1998
These Hercules cards are somewhat different. They have video in and out using ITT VPX3225D and Chrontel CH7003A chips. May work though.
Reply 6 of 12, by VooDooMan
ph4nt0m wrote:
VooDooMan wrote:
Here you go:
Strange... it works for me 😀
So maybe try here:
https://ufile.io/3qd4b
Reply 8 of 12, by Stiletto
ph4nt0m wrote:
VooDooMan wrote:
Here you go:
Working fine here.
do the Fandango!" - Queen
Stiletto
Reply 9 of 12, by ph4nt0m
Burnt the BIOS into a Winbond W27C512 EEPROM chip. My test machine boots up showing nothing on screen. Booting again with the V2200 as a secondary card. It shows up as a standard VGA adaptor with the PCI ID corresponding to Rendition V2200. Hangs up if I try to install the drivers, though not surprising without a readable BIOS chip. If anyone has such a reference V2200 without a sticker on the BIOS chip, could you tell me the part number? It can be either a one time programmable ROM, UV erasable PROM, EEPROM or flash.
Reply 10 of 12, by kreksoverzum
ph4nt0m wrote on 2019-03-15, 20:40:
Greetings, @ph4nt0m. Have you completed this peculiar task? I am in the exactly same situation here. And, by the way, links to download ROM file are no more valid. Could you please resubmit this file as an attachment?
Reply 11 of 12, by Tiido
Here's a V2200 BIOS I have dumped a while ago
    V2200.zip
    19.04 KiB
    7 downloads
    noname V2200 AGP card BIOS
Reply 12 of 12, by kreksoverzum
Tiido wrote on 2024-05-21, 21:18:
V2200
Thank you very much. Sorry, i havent tried your rom, i flashed bios from https://www.vgamuseum.info/index.php/companie … on-verite-v2200 into winbond W27C512-45Z eeprom chip twice and it suited perfectly! I am also attaching it for history purposes.
    V2200.zip
    19.04 KiB
    8 downloads
    Rendition V2200 bioses from vgamuseum.info
    260.02 KiB
    Rendition V2200
    33.72 KiB
    Rendition V2200 start screen
