Reply 120 of 432, by matze79
112 KiB
78.83 KiB
All PC-Speaker issues are fixed now and now its also short circuit safe.
Co2 - for a endless Summer
Reply 124 of 432, by keropi
matze79 are these changes documented so I can replicate them?
🎵 PCMIDI mpu site buy+info
🎧 WIP Orpheus soundcard site
Reply 125 of 432, by matze79
more or less 😀
i send you a PM keropi.
Carlostex, we working out the bugs, i'm sure it will be avaible soon on serdaco 😀
Reply 126 of 432, by ITzTravelInTime
I hope you post some pcb files or something like that, i'd like to play with the disgn a little bit (just to match the holes and the headphone jack position to use the metal bracket i use for the adlib clone) and also because i'd like to build one from scratch, what a bout availability in the future? i'd like to use it with my upcoming pc xt build
Reply 127 of 432, by root42
matze79 wrote:
more or less 😀
I also still have one of your early prototype boards. Any chance I can upgrade it as well?
YouTube and Bonus
Reply 129 of 432, by matze79
Just have a little patience 😀 until ~ spring 2019!
Reply 130 of 432, by matze79
still some small adjustments needed, current progress :
1.57 MiB
Reply 132 of 432, by root42
God we need someone with a tool for making custom brackets. But yeah, looks lovely!
YouTube and Bonus
Reply 134 of 432, by matze79
ah i already have a solution for that into mind 😀
Reply 136 of 432, by matze79
looks lovley but has EMV problems.. so needs redesign i cut few things on the pcb and wired the gnd and vcc directly to power supply and so on..
still noise inside the signal.
my two testing boards on perfboard did work fine.. so it must have todo with the pcb design..
Reply 137 of 432, by root42
That is something that eludes me completely. How does one go about reducing noise on the PCB level? I remember one video by Dave from EEVblog where he simply added two layers to an already two layer board, simply by adding one pure GND and VCC plane, iirc. That supposedly reduced emissions as well. Not sure about the physics behind that.
YouTube and Bonus
Reply 138 of 432, by matze79
this way parasitic capacitance is eliminated i think.
Reply 139 of 432, by Tiido
Planes increase parasitic capacitance, which (un)intentionally helps to round off the signal edges slightly which will reduce emissions. Their main positive effect comes from reduction of loop area on return currents etc., the noise can couple straight into the plane rather than through other stuff elsewhere, so less has to radiate outwards or into other stuff.
