DOSBox debugger
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Re: DOSBox debugger
Postby LABS » 2018-7-25 @ 21:43
Is there a way to dump code overview to a file?
User avatar
LABS
Re: DOSBox debugger
Postby Qbix » 2018-8-31 @ 12:38
updated first post with binary of 0.74-2.
Water flows down the stream
User avatar
Qbix
DOSBox Author
Re: DOSBox debugger
Postby junglemontana » 2019-3-30 @ 17:34
These are old posts, but I agree that such features would be highly useful. Especially the ability to set a memory read breakpoint.
manku wrote:Would be really nice if debugger has ability to set breakpoint on *read* access on some memory fragment. Something like
BPMR [segment]:[offset] [length]
E.g. BMPR 0010:0100 0A -> break program execution if reading from 0010:0100-0010:01009 occured.
egons wrote:all things what i want from debugger:
1. conitional BP's like bp if edx=value. this feature supported in Syser kernel debugger.
I saw some patches that implement break-on-read, but they were very old.
Someone mentioned using OllyDbg to attach into DOSbox but it sounds rather complicated. Also, OllyDbg is Windows software. I guess it gets even more complicated on Linux.
junglemontana
Re: DOSBox debugger
Postby voxel » 2019-5-13 @ 09:48
Thanks for making the debugger available, it seems very useful! I would like to know if there is some way to automate sending commands to the debugger, perhaps via a script? For instance, if I need certain breakpoints set each time it would be nice to be able to have these defined in a file that is run when the debugger is launched, or to set BPINT 3 * for every launch.
voxel
Re: DOSBox debugger
Postby junglemontana » 2019-6-16 @ 10:41
Another feature that would be useful, I think: Ability to declare variable sizes and arrays with the IV command.
For example:
IV [seg]:[off] [name] --- this is what we have now
IV [seg]:[off] [name] [size] --- declare a variable with a specified size
IVARR [seg]:[off] [name] [n_elems] [elem_size] --- declare an array of n_elems elements having a size of elem_size
junglemontana
Re: DOSBox debugger
Postby Qbix » 2019-6-26 @ 19:03
Updated first post with 0.74-3.
User avatar
Qbix
DOSBox Author
Previous
Return to DOSBox Development
Who is online
Users browsing this forum: No registered users and 0 guests
