Curious Crystal 8-bit ISA midi card, help identifying?
Discussion about old sound cards, MIDI devices and sound related accessories.
Postby pullasuti » 2019-4-08 @ 21:15
Greetings. New user, old nerd asking for id help.
A midi card caught my eye, and had to pick it up. Would be interesting to know what this was called back in the day. Has the 4110/4111 and 9203 set of chips, among others. Couldn't get it to work with a SB 2.0, even though no resource conflict should be going on. Works fine on its own, thought
Crystal
Next up, help me fix my dead CT3900 :)
pullasuti
Re: Curious Crystal 8-bit ISA midi card, help identifying?
Postby appiah4 » 2019-4-08 @ 21:29
I don't know what this car's name is but I know I envy it.
A500:Rev6|+512K|ACA500+|C1084S
i386:Am386SX25|4M|GD5402|ES688
i486:U5S33|8M|GD5428|YMF719|DB-S2
i586:P133|32M|T64+/MX2|V1|CT3980/32M
i686:K6-2/400|128M|Rage|V2|CT4520/32M
S370:P3-1200|384M|GF4-4200|MX300
S754:A3700+|2G|X1950PRO|SB0350
User avatar
appiah4
Postby cyclone3d » 2019-4-08 @ 21:34
Sweet looking card
Is there anything on the back of the card? Maybe an FCC ID?
Could be a prototype card if there isn't.
User avatar
cyclone3d
Postby Tiido » 2019-4-08 @ 21:50
This card does only MIDI, there's no SB or WSS compatibility on it.
User avatar
Tiido
Postby pullasuti » 2019-4-08 @ 21:56
I know, that's why I called it a midi card :)
The back doesn't reveal much, but it does have a serial number, so it's not alone.
Buttside
pullasuti
Postby badmojo » 2019-4-09 @ 06:06
That's cool! I'm going to go ahead and call it "Crystal SCC1"
Have you tried it? I'm wondering if it's an MPU-401 or if you need special drivers.
If it's broke, then fix it!
User avatar
badmojo
Postby appiah4 » 2019-4-09 @ 06:07
Look at that S/N 153437 - where are those other 150,000 cards!!!
User avatar
appiah4
Postby pullasuti » 2019-4-09 @ 06:46
badmojo wrote:That's cool! I'm going to go ahead and call it "Crystal SCC1"
Yes, works without drivers. Thank goodness :)
pullasuti
Postby root42 » 2019-4-09 @ 07:17
Extremely cool and obscure card. I suspect it collides with the MPU interface of the Sound Blaster? Can you disable that? The older ones at least have a disable MPU jumper.
Soldering, retro game reviews and more on YouTube and Bonus videos
80386DX@25 MHz, 8 MiB RAM, Tseng ET4000 1 MiB, Jazz16, PC MIDI Card + SC55MkII + MT32, XT CF Lite, OSSC 1.6
User avatar
root42
Postby Scali » 2019-4-09 @ 07:27
I was somewhat confused by 'MIDI card'.
I suppose you mean it contains a wavetable synthesizer, and I assume it would be compatible with the (dumb) MPU-401 interface.
It seems like this uses components commonly found on WaveBlaster boards (Dream MIDI synthesizer and effects processor), such as the Terratec WaveSystem.
However, the fact that it has 3 jacks seems to imply that it also has audio input capability.
Scali
Postby appiah4 » 2019-4-09 @ 07:40
Scali wrote:I was somewhat confused by 'MIDI card'.
My understanding is that it has a hardware mixer so you can input audio from a regular soundcard, mix with the wavetable music and output as a mixed audio.
Very, very cool card!
User avatar
appiah4
Postby pullasuti » 2019-4-09 @ 08:17
root42 wrote:Extremely cool and obscure card. I suspect it collides with the MPU interface of the Sound Blaster? Can you disable that? The older ones at least have a disable MPU jumper.
Ah, could be. Though I did try different addresses for the card itself, but could see what happens if I set the SB 2.0 to disable "game port".
Yes, the card has line in, line out and spk out. Very loud by default, and somewhat noisy. Don't know if there has been software to control these.
pullasuti
Postby keropi » 2019-4-09 @ 08:26
interesting card, how does it sound?
User avatar
keropi
Postby Scali » 2019-4-09 @ 08:27
pullasuti wrote:Yes, the card has line in, line out and spk out. Very loud by default, and somewhat noisy. Don't know if there has been software to control these.
I would expect that there are SysEx commands to control this, if it can be controlled at all.
Scali
Postby appiah4 » 2019-4-09 @ 08:52
You definitely need some kind of software driver for that I would think.
User avatar
appiah4
Postby pullasuti » 2019-4-09 @ 09:53
keropi wrote:interesting card, how does it sound?
I suppose it's OK. Did some quick recordings, because this system was originally for FM/MT-32 era, and didn't have that many SC/GM games. Others seem fine, but the intro to UFO/XCOM is completely messed (could be because I just threw versions 1.2 and 1.4 over the original). Should record the same tracks with SB16 and a Dream waveblaster board when have more time.
Sounds of dossy music (Doom, Doom 2, Dune 2, Hand of Fate, Raptor, Sam & Max, UFO).
pullasuti
Postby badmojo » 2019-4-09 @ 12:24
Sounds great to me, nice find.
Gah, now I want to play Dune2 again :blah:
User avatar
badmojo
Postby CHiLL72 » 2019-4-12 @ 11:41
Could this be an Orchid card? I see similarities between this card and this one: http://members.home.nl/c.kersten/WaveBlaster%20MIDI%20daughterboards/Orchid%20Wave%20Booster%204FX%20(2014-03-17).png
A predecessor to the Orchid GameWave 32 perhaps?
Looking for Roland MIDI modules or cards? http://members.home.nl/c.kersten
User avatar
CHiLL72
Postby tpowell.ca » 2019-4-12 @ 13:47
badmojo wrote:Sounds great to me, nice find.
I agree with both these statements.
It really does sound great and well balanced.
    Merlin: MS-4144, AMD5x86-160, 32MB, 16GB CF, ZIP100, ESS688, GUS, S3 VirgeGX 2MB, HardMPU
    Newton: K6XV3+/66, AMD K6-III+500, 256MB, 32GB SSD, AWE32, GUS 16MB, Voodoo3-3k
    Einstein: P8P400, P4-3GHz HT, 1.5GB, Quadro4 980XGL, Live!
User avatar
tpowell.ca
Postby cyclone3d » 2019-4-12 @ 14:44
CHiLL72 wrote:Could this be an Orchid card? I see similarities between this card and this one: http://members.home.nl/c.kersten/WaveBlaster%20MIDI%20daughterboards/Orchid%20Wave%20Booster%204FX%20(2014-03-17).png
Fixed your link for you.
Very interesting. If it were Orchid, I would think that it would have it silk screened on the card though.
User avatar
cyclone3d
Next
Return to Sound
Who is online
Users browsing this forum: hard1k and 3 guests
