I had a quick look over the 120 PSUs I bought and did some work to a few of them:
Premier LC-8500BTX (1) - just needed to be cleaned of dust, works fine. Looks like a solid 250W unit, although it has 13009 equivalent transistors and 6 pin PCI-E
Frontier LC-8460BTX & G-Alantic ATX-450P2SC - former was the most gutless Deer I had on my hands, and it had no redeeming qualities - saved the casing, threw the fan and PCB away, and swapped the G-Alantic (Channel Well/CWT ISO is the OEM) PCB and fan (Yate Loon) inside the Frontier casing.
Casecom ATX450 - this one just had bad caps in the output section. Replaced bottom casing with a version that has a removable wire grille, recapped, everything's happy. Sun Pro is the OEM.
Left to do: swap in a KeyMouse (Rexpower PL-450) PCB inside a 400W Premier LC-C400ATX casing. (the old PCB inside had sparked and I couldn't fix it.)
