First post, by red_avatar
With all the different options I have now for DOSBOX (mount iso, mount several seperate drives, etc.) it's becoming increasingly clearer that I should start having a menu instead of having to manually alter the settings each time.
My old IBM 386 had a cool menu program that looked simple and I'd love to have something similar (not to mention, for nostalgic value). Does anyone know a program that could make a menu that resembles this old menu? I know there's quite a few programs out there for making menus but I can't seem to find any that will make it something similar like this.
Plus I think quite a few people would like a program like this, even if just for games.
Reply 1 of 8, by Melroc
As far as i know you can download several frontends for DOSBox from their homepage that would serve your purpose.
Not very nice but functional 😉
Under DOS, programs like "qmenu" or "quickmenu" would be a good choice.
Reply 2 of 8, by rcblanke
Hi red_avatar,
I totally agree that front-ends like D-Fend might be what you need, so you can customize and tweak Dosbox' settings. However, if you want a true dos menu program, might I suggest my own 'Access' (http://home.quicknet.nl/qn/prive/blankendaalr/ or http://surf.to/AccessDosMenu)?! There is a speedy text-mode version, and Access comes in multiple graphical versions as well if you'd want that. Both English and Dutch releases are available.
Also, Gaze or Glance might be interesting dos menu programs (http://www.filelibrary.com/Contents/DOS/52/3.html).
Regards,
Ronald
Reply 3 of 8, by swaaye
BE A MAN AND WRITE IT YOURSELF!!!!!!!!11!! 😀
Allow me to whip up a nice template.
config.sys
[menu]
menuitem=WIN, Windows98
menuitem=XMS, DOS XMS
menuitem=EMS, DOS EMS
menuitem=4GW, Protected Mode games
[common]
[WIN]
[XMS]
DEVICE=C:\WINDOWS\HIMEM.SYS
DEVICE=C:\WINDOWS\EMM386.EXE NOEMS I=B000-B7FF
DOS=HIGH,UMB
FILES=30
BUFFERS=10
[EMS]
DEVICE=C:\WINDOWS\EMM386.EXE RAM I=B000-B7FF
DOS=HIGH,UMB
FILES=30
BUFFERS=10
[4GW]
FILES=30
BUFFERS=10
autoexec.bat
@ECHO OFF
PATH=C:\;C:\WINDOWS;
GOTO %CONFIG%
:WIN
WIN
GOTO END
:XMS
SMARTDRV
LH DOSKEY
GOTO END
:EMS
SMARTDRV
LH DOSKEY
GOTO END
:4GW
SMARTDRV
LH DOSKEY
GOTO END
:END
Don't forget to edit your msdos.sys file and change the gui=1 to 0 so it doesn't start Windows automatically. And, of course, you need your sound card, mouse, and cdrom stuff!! This is also assuming you're running Windows 9x. If you're using DOS 6 you need to change the /WINDOWS/ to /DOS/
Reply 4 of 8, by red_avatar
Frontends are for Windows babies 😜 I just wanted an authentic DOS menu, and I found it with 3DMenu which does everything I wanted. It's far quicker than D-Fend too. It also looks quite a bit like that IBM menu, which is what I specifically wanted. Thanks anyway though.
Reply 6 of 8, by avatar_58
Hey...I don't have to worry about configuration once I backup my games with defend...so there. 🤣 I prefer to actually have all my games in a list with their own configs all ready to go.
Reply 7 of 8, by DosFreak
Probably the best benefit to an internal DosBox frontend is that it works across all OS's so if you use Linux/Windows/OSX alot you don't have to bother with host frontends and you don't have to worry about your frontend never working because if it works in DosBox it will probably continue to do so (at least more so than Windows where if you move your mouse you'll have to reboot). 😉
Make your games work offline
Reply 8 of 8, by avatar_58
Its still hard to set certain options from within dosbox (scalers etc). If the time comes where d-fend no longer works for me then I would rather do with no menu at all.
Of course, since d-fend creates conf files I could just stick them into the directories and a copy of dosbox. 😎 So thats my backup plan.
