Reply 160 of 455, by Tiido
Or you could clock another 74 by write (or two) to the PSG that then ungates the clock, no need for an extra MCU. Reset of that 74 would be controlled by ISA reset or a simple RC time constant.
Reply 161 of 455, by matze79
Yeah but DTK Floppy BIOS and other Option Rom`s seem to access the Port Adress of PSG and activate it.
Also EPSON IM BIOS trys to access 0C0.
So i needed a more flexible solution.
I tried with a flip flop before which worked fine on 2c0 but never on 0c0.
And ISA Reset is only active on hard reset, but not within a soft reset (STRG+ALT+DEL)
I already use it to retrigger the MCU.
Reply 162 of 455, by Tiido
Aha ok, so MCU will be only foolproof solution.
Reply 163 of 455, by matze79
Found a new issue, when i cut the clock off from sn76489 - floppy bios hangs until the clock is attached back to sn76489
then it continues to boot.
This is only a issue on AT Computers. As 0C0 is unsupported because Second DMA Controller is using this Address.
Using 1E0 or 2C0h this is no issue at all.
Reply 164 of 455, by Tiido
You have to gate the Ready signal too then, it is controlled by the clock and will cause infinite bus cycle if there's no clock.
Reply 165 of 455, by matze79
it must be something else, if i bend the ready pin up, it also occurs.
no time anymore 🙁 for further investigations.
Tomorrow work.. so i have to wait until sunday.
EDIT:
deleted.
Reply 166 of 455, by matze79
Thanks again 😀
that did the Job, the SN76489 was defective i replaced it and now it works by gating clock and ready.
Reply 167 of 455, by Tiido
That's good news ~
Reply 168 of 455, by matze79
only gating the two brings problems 😒
i need to fully cut the sn76489 from bus then.
Reply 169 of 455, by Tiido
That makes no sense, there's no read function on the chip that I know of, the inputs are all actual inputs according to silicon shots...
Reply 170 of 455, by matze79
yeah i know that, also does make no sense to me. i need to hookup my oscilloscope to see whats happening here..
everything is wired correctly, i triple checked it.
EDIT:
simple things may prevent from success..
just add the damn capacitor 😉
Reply 171 of 455, by matze79
So finally i got it working, was bit challenging,
a pull up is required on SN76489.
i also did not add a capacitor which caused various symptoms,
i thought for a short test it will suffice.
Also breadboard has loose contacts, i throw it away..
i had a real huge series of mistake.
so i throw all away and started over again.
Damn it works ! 😀
Not bad for a Bakermen 😉
Reply 172 of 455, by dreamblaster
matze79 wrote:
So finally i got it working, was bit challenging, a pull up is required on SN76489. […]
Damn it works ! 😀
Great news, congratulations ! 😀
Thanks for your support !
Reply 173 of 455, by root42
Hmmm…
https://youtu.be/ymdssZOAx3Q
YouTube and Bonus
Reply 174 of 455, by matze79
all is tested, i rerouted changes and order pcb 😀
138.53 KiB
Reply 175 of 455, by Tiido
Oho, a proper prototype ! Very nice ~
Reply 176 of 455, by matze79
Yeah its better to verify every change to ensure it will work as i wanted 😀
Current progress:
129.08 KiB
silkscreens needs some clean up.
LM386 needs to be turned to match other ICs.
i`m testing Decoder for 0x205 now.
for IBM PS/1 3 Voice Support.
Reply 177 of 455, by matze79
Good news, got next boards, now i verify all changes 😀
Then we go one Stop further.
Bracklets!
Reply 178 of 455, by matze79
New Driver for Port Redirection without need of QEMM386 or EMM386 is in development.
    3.08 KiB
Reply 179 of 455, by dreamblaster
Nice !
