First post, by Hamby
- Oldbie
I've been wanting to do more and more on DOS systems, and one of the things is music creation.
The system I'll be using will most likely be a 486 DX2/66, and probably with a Soundblaster Awe32.
Do I need/want an MT-32? I've seen several videos and reviews (LGR and 8-Bit Guy, for example) of the MT-32, and the music for games etc is much better than stock adlib or soundblaster. Reading up on the Awe32, however, I got the impression it's capable of generating music quality on a par with an MT-32. Also, if I do get an MT-32, will I need an MPU401 to use it with the Awe32?
I have an old casio LK-220 keyboard, but A) it's huge B) I can't conveniently locate it near the dos computer(s), C) it's USB.
I suppose I can get a USb -> Midi adapter, though I don't know if it would work in that direction (MT-32 midi to usb keyboard).
I'm also currently lusting after a Native Instruments Komplete Kontrol M32 Midi keyboard.
I know I could connect this to my modern computer, but, again, I'd like to do creative work with my DOS computers... so, with a USB <-> MIDI <-> gameport adapters, would it even function with vintage DOS audio composition software?
Has anyone else set up to use their DOS machine(s) for music creation? If so, what are you using, what pitfalls did you encounter?
