Psycho Pinball
First post, by mundesley
I am new to dosbox but fairly PC literate.
I have managed to get one pinball game (Epic) installed and working, but every time I install Psyco and attempt to run, I get a message that the CD must be in the drive to run. I have tried mounting the CD Drive, but it won't install, and when I attempt to run from the mounted "C" drive I get the above message. How can I overcome this please.
Reply 1 of 7, by eL_PuSHeR
Please post here all the exact commands you typed in when mounting all drives.
[Moved to DOSBox Games/Apps]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 7, by mundesley
I have my games in a folder names "Oldgames", and I copy all files from the Psycho CD to the oldgames folder
To mount I type Mount c c:\oldgames
At the Z:> I type C:
At C:\ I type install
During the install I am asked to specify my CD drive, default is D, but I have tried both D & C but neither have any effect. A folder named Psycho is created on the mounted C:\oldgames, and after the installation completes it passes to a C:\psycho command, at which stage I have tried typing Psycho and _P_ both pass the next stage Dos4 protected mode etc and I reach a message to the effect "Psycho must me run from the C:\drive with the cd in your cd rom drive" that's not verbatim but near enough what it says.
Hope this helps to establish what I am doing wrong, as I note from other post's that other have successfully managed to run this game.
Many thanks
Reply 3 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
hmm you need to mount a d:\ as well ? else you can't install to it.
Water flows down the stream
Reply 4 of 7, by mundesley
I have tried mounting a D Drive as a CD drive, but I cannot install to it as it is a CD in the drive. Are you suggesting I mount a D Drive by some other method, if so what is the syntax please, how do I overcome the game asking for the CD in the drive. I have looked for an inf file to see if I can alter the location of D to C, but I am unable to find one.
Reply 5 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
mount c c:\oldgames
c:
mkdir result
subst d result
install
Reply 6 of 7, by HunterZ
mount c c:\oldgames
mount d d:\ -t cdrom
d:
install
You need to have BOTH your hard drive and CD drive mounted at the same time in order to install a game from the CD to your hard drive.
Reply 7 of 7, by mundesley
Hunterz thanks for that it worked a treat,
Qbix I haven't tried your solution as the other worked okay, I have copied and saved it for future reference though,
Thanks to you both once again.
