First post, by sirlemonhead
Hey,
I was taking apart my Dell 466L machine to take some photos of the board and realised I probably need to recap it as the SMD caps were definitely leaking on the board.
I noticed there seemed to be two different sets of pads for each capacitor. I asked about this on the eevblog but figured I'd probably get a better answer here. That thread is at: https://www.eevblog.com/forum/repair/smd-cap- … 232/#msg2315232
This photo should explain all: https://www.dropbox.com/s/1ryd6329nvzidxh/dellsmdcaps.jpg
I'd ideally not want to put new SMD caps on if I didn't have to, as they're a pain to get at in some locations, and the alternative pads would be 10 times easier to solder to.
Should I go with a different type, and if so what could I use?
Reply 1 of 9, by dkarguth
There are two major types of SMD capacitors.
This type:
which are used primarily for small values and tight locations
and this type:
which are used for larger values
It appears that the two sets of pads are for the two types of capacitors: the wider pads for the square ones, and the thinner/longer pads for the can style. If you can find the value that you need in the can style, it should work fine as long as there are no physical requirements.
As for using non-surface mount capacitor... dont. You will likely end up with a really messy result that has a high risk of shorting on somethings else, or even worse, ripping the pads off the motherboard if it catches on something. Just go through the trouble to solder new SMD caps. Try cleaning the pads, and then apply a small solder bead to the bare pad. Use tweezers to place the component on the pads, then touch the iron to each side to let the solder flow onto the component. If you don't have hot tweezers, that is the easiest way IMO. Or you could use solder paste, but it is rather expensive.
"And remember, this fix is only temporary, unless it works." -Red Green
Reply 3 of 9, by dkarguth
It ultimately depends on the application of the capacitor. In most applications that an electrolytic would be used, you can replace it with a tantalum. Ceramics do have some different behavioral aspects than electrolytics, so even if the capacitance is the same, it might not behave 100% normally. I would stick with the tantalum.
Reply 4 of 9, by gdjacobs
Polymer caps can now be used for much of the range of SMD electrolytics and are a good substitute for tantalum caps as well.
Reply 5 of 9, by luckybob
In the mass-production world, shit happens.
When you need to make 10,000 widgets and suddenly a specific part isn't available, you are screwed. So it is common to include multiple pads for different but compatible pieces when you can expect shortages of certain parts.
The manufacturer ran out of 100uf smd caps? Well just slap in an electrolytic on an adjacent pad. Boom, your order gets fulfilled and you get a bonus for having things to sell when there is a parts shortage.
look at this video card: http://www.vgamuseum.info/images/zaatharen/nv … _model2_fhq.jpg
Those memory pads under the installed memory are there for the same reason your caps have 2 sets of pads. Its just in the video card's case they had a backup plan for a different memory chip that had a different pin-out.
Reply 6 of 9, by sirlemonhead
I know those exist for the Can types, but do you mean these specifically? https://uk.farnell.com/c/passive-components/c … ymer-capacitors
Reply 7 of 9, by Intel486dx33
The PAD is part of the PCB under-lament. Part of the copper trace network. If the PAD is gone which is common when capacitors burst and leak acid onto the PCB board. Then you need to get some thin copper sheeting and cut out a NEW pad and trace line to repair. You need to glue down the NEW PAD to the PCB board and solder the new copper PAD trace line to the PCB board trace. Requires cleaning the PCB and scraping off some of the trace protective coating and then glueing on a NEW PAD and soldering the end to the original PCB trace line.
You need special glue and PCB trace shielding laminate.
And a microscope for sure as this is micro surgery.
And once you have the PAD and trace repaired then you can solder on a NEW capacitor.
https://youtu.be/vx50YtEC2S8
Reply 9 of 9, by gdjacobs
Panasonic has polymers in 2917 plastic packages.
Here's the app note where they delve into replacement options.
https://www.element14.com/community/docs/DOC- … ts-for-tantalum
