First post, by retropol
anyone has knowledge about jumper settings for the soundcard:
Aspar K9J057A0A
Chip: ES688FC
FCC ID: K9J057A0A
Information on board: P057-01-A0A
Year of construction: 1994
Reply 1 of 3, by einr
http://arvutimuuseum.ee/th99/i/I-L/51695.htm
This ES688 card is not 100% identical to your card but extremely close. Going by the diagram only the CD audio connector looks physically different. Probably the same board, populated with slightly different components and sold under different brands. Either way, the jumper blocks JP1, JP4 and JP5-JP9 seem to be in the same position and configuration so I'd wager that they should work the same.
Reply 2 of 3, by retropol
einr! THANK YOU A LOT!!! this is it 😀 almost... but whats needed I got!
Reply 3 of 3, by jwoods
I just got the same soundcard, so glad I came across the post!
Did you the wavetable header working perchance? I've not tried yet, but saw in those jumper settings that none of them seem to mention separate wavetable IRQs or addresses...
