Quake III Arena Benchmark Thread
Reply 160 of 222, by SPBHM
rcarkk wrote:
Just to confirm the settings. Should we use the absolute maximum settings and 32bit colors except trilinear filtering? Or should we use high quality preset settings without trilinear filtering?
I'm using the settings from the OP
https://abload.de/img/q3a_settingsvcs4v.png
unless I specify on my post that I used something else.
it would've been easier to avoid mistakes if it was just about using one of the settings profile, well, I suppose we should just say the settings we are using when posting a result, be it "op settings" or "high quality" or whatever!
Reply 161 of 222, by rcarkk
Thanks. I did used those settings...except on the V2 SLI. I had to put the second highest texture setting, because they only have 8MB for textures. They only scored 11fps with max texture settings.
Baby AT socket7 - Pentium MMX 233MHz + 3Dfx Voodoo
Socket 8 build - Soyo 6FA + Pentium Pro 200MHz + 3Dfx Voodoo 2 12MB
PC Remake - Pentium III 450 + Matrox G400 16MB
The K6-III build
Reply 162 of 222, by cxm717
rcarkk wrote:
My results for a Matrox G400 32MB and 2x 3Dfx Voodoo 2 12MB in SLI on a Pentium III-S 1.26Ghz running on a QDI Advance 10T with […]
My results for a Matrox G400 32MB and 2x 3Dfx Voodoo 2 12MB in SLI on a Pentium III-S 1.26Ghz running on a QDI Advance 10T with Via Apollo Pro 133T and 256MB of PC133 at 2-2-2-2 timmings. Sound card is a Live! 5.1 digital and OS is Win98 SE.
6.23 drivers + G400 @125/166Mhz = 38.1fps @16bit
6.23 drivers + G400 @125/166Mhz = 25.4fps @32bit
Latest reference drivers + Voodoo 2 12MB SLI = 28.2fps @16bit (with 2nd highest texture resolution, because at max res, the framerate is very low due to only 12MB)
You should try the matrox TurboGL on your G400, you need to install a 5.xx driver though IIRC.
Reply 163 of 222, by rcarkk
I think i had tried it, and the OpenGL ICD of the 6.23 drivers, were faster than older drivers with TurboGL. But i need to check that again. One thing i did notice is that the G400 takes a huge hit with Trilinear filtering enabled in Quake 3. This benchmark requiring Bilinear filtering because of V2 is actually benefiting the G400 performance figures.
The K6-III build
Reply 164 of 222, by rcarkk
My results for an Asus V3400TNT Riva TNT 16MB and one 3Dfx Voodoo 2 12MB on a Pentium III-S 1.26Ghz running on a QDI Advance 10T with Via Apollo Pro 133T and 256MB of PC133 at 2-2-2-2 timmings. Sound card is a Live! 5.1 digital and OS is Win98 SE.
21.83 + Riva TNT 16MB = 22.4fps @1024x768 16bit
21.83 + Riva TNT 16MB = 13.4fps @1024x768 32bit
Latest reference drivers + Voodoo 2 12MB = 31.8fps @800x600 16bit (with 2nd highest texture resolution, because at max res, the framerate is very low due to only 12MB)
21.83 + Riva TNT 16MB = 35.7fps @800x600 16bit (with 2nd highest texture resolution, to compare with Voodoo 2 12MB texture limitation)
I´m impressed. The Riva TNT is scoring higher all across the games i tested. This is true in Direct3D and OpenGL. Not much faster, but faster. Even UT at 800x600 16bit, runs at 47fps on both cards. And the TNT is using D3D vs the almighty Glide on the Voodoo 2.
I did notice that the image quality is better on the Riva TNT compared to Voodoo 2, even at 16bit. I never thought that the TNT was clearly superior to the Voodoo 2 12MB.
The K6-III build
Reply 165 of 222, by SPBHM
I thought it was fairly interesting how close the results I got with the VIA P4M266 IGP (ProSavgeDDR, Savage 4 based IGP from 2001/2002) are to the TnT 16MB,
the CPU is not the same but I doubt it's having much of an impact with this level of IGP, (and the northwood Celeron is incredibly slow for how high clocked it is)
IGP is overclocked to 154Mhz and the ram is DDR 266
The attachment celeron21-q3-oc.JPG is no longer available
OP settings
I also tested with 16 bits and it got 22.6FPS
and with 800x600 16bit and the texture quality reduced by 1 it got 36.5 (it actually made no difference to performance running with max or 1 step down)
Reply 166 of 222, by rcarkk
SPBHM wrote:
I thought it was fairly interesting how close the results I got with the VIA P4M266 IGP (ProSavgeDDR, Savage 4 based IGP from 20 […]
OP settings
This means a standard S3 Savage 4 Pro 32MB is slower than a Riva TNT 16MB. The scores of the TNT i posted are with no OC. Weird, i thought that the Savage 4 Pro from 1999, was faster card than the TNT from 1998
The K6-III build
Reply 167 of 222, by cxm717
I tried Q3 on a 32MB Rage 128pro and 16MB Savage4 in my OR840/P3800/512MB 800 RDRAM system.
First the Rage:
The attachment p3r128psys.png is no longer available
The attachment q3rage128p6292.png is no longer available
And the Savage4:
The attachment s3s4ep3sys.png is no longer available
The attachment s3s4eq3.png is no longer available
Reply 168 of 222, by SPBHM
OP settings
when I started testing this IGP I started looking around for savage 4 results and the IGP looks slower, it didn't look massively slower when comparing IGP with OC vs stock Savage 4, but still looked slower, but stock vs stock and OC vs OC the discrete card should be faster, as @cxm717 shows, with very close clocks the Savage 4 Pro is 50% faster than the ProSavageDDR IGP in this test!
the only thing is that I'm using windows XP, it might be possible that the IGP is better with 98 drivers,
because AFAIK the IGP has the same number of pipelines/tmus as Savage4 and the same the design, it might be that the shared memory is a significant performance penalty.
Reply 169 of 222, by rcarkk
cxm717 wrote:
I tried Q3 on a 32MB Rage 128pro and 16MB Savage4 in my OR840/P3800/512MB 800 RDRAM system. […]
First the Rage:
And the Savage4:
Great results for your Savage 4. Your card is running stock at 160/166Mhz on GPU/RAM. That´s very fast and much faster than reference Savage 4 Pro clocks of 125/143Mhz.
What card do you own?
The K6-III build
Reply 170 of 222, by rcarkk
SPBHM wrote:
when I started testing this IGP I started looking around for savage 4 results and the IGP looks slower, it didn't look massively […]
OP settings
Maybe the clocks of the Savage 4 based IGP is running with low clocks. You need to open Powerstrip to see the clocks...
Edit: My mystaque. Yes, your Savage 4 IGP is OC to 152Mhz. Yes, maybe the shared system memory is slowing the IGP.
The K6-III build
Reply 171 of 222, by cxm717
First the Rage:
And the Savage4:
It's a number nine card. I really like it, it has much better quality output compared to my other S3 cards.
Reply 172 of 222, by cxm717
Here is my Geforce256 SDR on the same OR840 setup:
The attachment p3gfsys.png is no longer available
The attachment q3gfsdr3082.png is no longer available
Reply 173 of 222, by RoyBatty
CPU-Z reports wrong CPU freq, it's actually 4.4ghz (same as north bridge). The elusive 1k FPS.
The attachment quake3demo.jpg is no longer available
Reply 174 of 222, by rcarkk
Very good fps for the GF256 SDR. Can you do another benchmark with Trilinear filtering enabled?
My V5 5500 on a PIII Coop 866Mhz scored only 51.7fps @1024x768 with Trilinear filtering on, and the TNT2 Ultra is scoring 31fps in the same machine and same settings.
I always thought the V5 5500 is faster than GF256 SDR and the TNT2 Ultra was only 30% slower than GF256 SDR.
The K6-III build
Reply 175 of 222, by rcarkk
cxm717 wrote:
First the Rage:
And the Savage4:
Is the card overclocked with those 160/166Mhz settings?
The K6-III build
Reply 176 of 222, by cxm717
Nope. The card was running stock clocks. Here are some pics of the card https://imgur.com/a/jR9lfNo
Reply 177 of 222, by cxm717
Here are some stock and OC results on my G400Max. Both running the 555 driver with the 1.3 TurboGL.
The G400 at stock clocks:
The attachment g400sys.png is no longer available
The attachment g40032.png is no longer available
and OCed:
The attachment g400ocsys.png is no longer available
The attachment g400oc32.png is no longer available
Reply 178 of 222, by cxm717
rcarkk wrote:
Very good fps for the GF256 SDR. Can you do another benchmark with Trilinear filtering enabled? My V5 5500 on a PIII Coop 866Mh […]
I can run more tests once I'm done with the G400. From what I remember the Geforce got about 55fps with trilinear. Keep in mind this version of Q3 defaults to s3tc enabled, that probably makes a difference (for the SDR version at least). New versions of Q3 seem to default to disabled.
Reply 179 of 222, by bofh.fromhell
My contribution to the 2000 GPU & CPU period correct list:
Athlon 1200C.
ABIT KG7 with AMD 760 chipset (released nov 2000)
Gainward GeForce2 Ultra, 71.89 drivers.
1GB DDR memory, super tight 2-2-2-2-6 settings.
Soundblaster Live! (SB0060), funny enough I get better results with sound on.
Windows 2000 with Unofficial SP5.
Nothing overclocked.
Amazing machine IMO.
And rock solid since the recap, zero problems.
Can't belive that I never payed attention to the 760 chipset when it was current.
The Y2K machine is only missing a few parts now =)
