CPU Upgrade Confusion
First post, by Gazirra
I'm currently running a WIN98 system with a slot 1, PII 350, and I had wanted to upgrade it. So, I went onto Newegg and purchased a new CPU, a PIII 933. I may not use it due to the need to overclock, but there's still something I need to know.
The listing on Newegg called it a slot 1 CPU. What I got in the mail doesn't look like one to me.
These are the parts that I received today:
Did I get the wrong thing?
Reply 2 of 7, by Gazirra
My MB is an AOpen Ax6bc. I bought this when I first learned that slotkets could allow for a more powerful CPU than the manufacturer says the board can use. Also, at the time I still owed Ebay some money and I couldn't order from them. I've since paid that off. I paid about $20 for this
Reply 3 of 7, by cyclone3d
Well, you could get a slotket... or you could send that back for a refund and get a Slot 1 CPU.
Looking stuff up, it looks like people were able to use that board all the way up the the 153Mhz fsb setting with the BIOS that added support for the higher bus speeds.
Here is a 1Ghz Slot 1 for $29 shipped on eBay.
https://www.ebay.com/itm/Intel-Pentium-III-PI … an/293074466850
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 7, by rasz_pl
cyclone3d wrote:
How much was that on Newegg?
Why not get a used one off of eBay?
this is Newegg playing Amazon, they arent selling those, merely fronting some third party Chinese reseller, so its the same as buying on ebay,
werent 1ghz P3 coppermines unstable and recalled? or was that 1.13GHz?
Reply 5 of 7, by Deunan
AFAIK just the 1.13GHz. The story goes Intel tried to match (actually, even slightly outdo) AMD Athlon clock world-first, but their CPU fell flat on it's face when the various benchmarking sites noticed it's unstable. Intel recalled most of the stock.
Reply 6 of 7, by cyclone3d
This is correct. It was just the 1.13Ghz Coppermine ones.
YMF7x4 Guide
Reply 7 of 7, by SPBHM
I would only recommend slotkets (lots of different ones and potential compatibility issues) if it's for a Tualatin (clearly better than the best Slot 1 CPUs are), unless you get lucky and find a very good one easily.
in your case returning this Socket 370 CPU and getting a Slot 1 Coppermine from ebay makes more sense
