Reply 100 of 164, by LABS
- Member
Is there a way to dump code overview to a file?
updated first post with binary of 0.74-2.
Water flows down the stream
These are old posts, but I agree that such features would be highly useful. Especially the ability to set a memory read breakpoint.
wrote:Would be really nice if debugger has ability to set breakpoint on *read* access on some memory fragment. Something like
BPMR [segment]:[offset] [length]
E.g. BMPR 0010:0100 0A -> break program execution if reading from 0010:0100-0010:01009 occured.
wrote:all things what i want from debugger:
1. conitional BP's like bp if edx=value. this feature supported in Syser kernel debugger.
I saw some patches that implement break-on-read, but they were very old.
Someone mentioned using OllyDbg to attach into DOSbox but it sounds rather complicated. Also, OllyDbg is Windows software. I guess it gets even more complicated on Linux.
Thanks for making the debugger available, it seems very useful! I would like to know if there is some way to automate sending commands to the debugger, perhaps via a script? For instance, if I need certain breakpoints set each time it would be nice to be able to have these defined in a file that is run when the debugger is launched, or to set BPINT 3 * for every launch.
Another feature that would be useful, I think: Ability to declare variable sizes and arrays with the IV command.
For example:
IV [seg]:[off] [name] --- this is what we have now
IV [seg]:[off] [name] [size] --- declare a variable with a specified size
IVARR [seg]:[off] [name] [n_elems] [elem_size] --- declare an array of n_elems elements having a size of elem_size
Updated first post with 0.74-3.
This may be a dumb question, but how does the IV command actually work? Or what are its limitations? I started a program (protected mode NE exe) under the debugger by doing "debug program.exe", then used the IV command to name some addresses as variables. I also saved the variable list with the SV command.
When the program reached the part where these memory location were accessed, the variables in the variable list showed just 0000 or some other invalid values, not the actual values of these memory locations. Also, the saved file doesn't contain the addresses in the format which I typed them in.
Also, I noticed that the Alt+X key combo doesn't work with my SVN version 4254 on Windows, see:
DOSBox Compilation Guides
Using the D command works of course, but it's slower and less convenient.
wrote:if you have experience with debugging you can try the DOSBox debugger DOSBox debugger EXE 0.74-3 DOSBox debugger EXE 0.74-2 DOSB […]
All these builds are crashing at launch (Error c0000005). My system is Win7sp1x86. Every other build of DosBox works fine (I've tried official 0.74.3, SVN r4259, SVN Daum, ECE r4259 and DosBox-X). Can you please fix the problem?
voxel wrote on 2019-05-13, 09:48:Thanks for making the debugger available, it seems very useful! I would like to know if there is some way to automate sending commands to the debugger, perhaps via a script? For instance, if I need certain breakpoints set each time it would be nice to be able to have these defined in a file that is run when the debugger is launched, or to set BPINT 3 * for every launch.
I really liked this idea. I've created a patch for 0.74-3 that does just this. I've attached both the patch and a binary. The changes to dosbox.conf should look like this:
[debug]
# autoexec: Automatically run commands on debug startup from the file specified.
autoexec=debug-autoexec.txt
This can be a full path to any file on your computer. This file contains a list of debugger commands. For example:
BPINT 3
BP 01DD:0107
If you intend to apply the patch, please note a couple things:
1. In debug.cpp I needed to change the switches for keypresses from (toupper(key)) to just (key) based on other posts in this topic. This may not be necessary based on your environment. I'm using MinGW with PDCurses 3.4 on Windows 10.
2. When applying this patch to trunk, #define MAXCMDLEN 254 is already defined in the latest debug.cpp, so you can leave that out of the patch.
3. The patch also includes changes so that BPINT 3 will break on an INT3 (0xCC) instruction as well as INT 3 (0xCD 0x03).
Have fun!
EDIT: Proper license in attachments and modified the patch to use the standard library for reading the autoexec file.
EDIT 2: See post below for updated files against the SVN.
EDIT 3: A new version is located here.
I would like to set a breakpoint on memory reads . That's the only thing I really miss.
@voxel @siddhartha: That's a real nice feature mate.
I have compiled DOSBox on Windows with debugger enabled.
Everything works fine, except Fn keys.
If I press ALT-pause, DOSBox will pause execution but pressing F5 won't do anything (DOSBox won't resume).
I took a look at code. To make it work I had to remove the following toupper() call in debug.cpp :
switch (toupper(key)) { ... }
It's clearly a hack (I mean what I did to make it work). Something else must be wrong. Any idea?
I used the guide described here
When I paste to much characters in the debugger window, the debugger prompt hangs.
Only work around I found is to press F3, then all returns to normal (Linux, latest SVN, heavydebug)
The links in the first post don't seem to work anymore? Or is this a temporary glitch?
thanks. I removed the non-working ones.
Will see if I have those files somewhere
jal wrote on 2020-10-09, 11:56:The links in the first post don't seem to work anymore? Or is this a temporary glitch?
I am having a weird issue in latest Chrome Beta this morning where clicking on the link doesn't start the download, but clicking to open in a new tab will.
I haven't troubleshooted it yet but maybe you are having the same issue.
do the Fandango!" - Queen
Stiletto
Indeed! That seemed the case, even though I'm running an offical build (85.0.4183.121). Funnily enough, even middle-button click, which should also open in new tab, doesn't work, the tab closes immediately. But opening a new tab from the context menu works. Really weird...
Version 2 of my autoexec patch includes support for BPINT [intNum] [ah] [al] breakpoints. This is taken with help from the DOSBox-X fork.
EDIT: See below for updated patch against the SVN.
You really should consider making your patch against SVN -- case in point: https://sourceforge.net/p/dosbox/code-0/3849/
There are many other improvements to the debugger in SVN as well.
Well that's embarrassing. I'll make an autoexec patch against the SVN (assuming it's not in there already).
EDIT: Attached are the updated files.
EDIT 2: New version is located here.
Akuma wrote on 2020-06-03, 08:16:I would like to set a breakpoint on memory reads . That's the only thing I really miss.
i try to implement that feature: how to add read/write data breakpoint?
maybe you can have a look and help with the idea/implementation
