First post, by Qbcd
Hi guys,
This is my first post, it's an honor to join this community, I've been lurking for quite some time. I recently embarked on a project to rebuild my childhood PC, and I started with buying this kickass Baby AT case:
As you can see it has that positively badass red flip power switch, reminiscent of the original IBM PC. However, the issue I'm having is that I want to replace the 25-year old AT PSU it came with with a new ATX PSU and use an adapter like this:
The problem is that the power switch has 4 wires coming off of it (plus a ground wire coming off the AT PSU end) and the adapter only has one black and one green wire. So how do I connect these? I assume the black wire goes to where the black wire from the AT PSU used to be. But what about the blue, brown, and white ones? And what about the green wire from the adapter? This is what the power button connections look like:
Help is greatly appreciated!
