First post, by Intel486dx33
I have a 486 motherboard with some cache.
It looks like the cache ram is 512kb but the tag is a 256kb chip.
So my computer will only see 256kb of ram.
Is the tag ram chip the wrong one for these 512kb. Cache ram chips ?
The motherboard can support up to 512kb of cache.
When I set the motherboard jumpers for 512kb it only sees 256kb.
See photo.
Reply 2 of 17, by Intel486dx33
I did, please read first message again. I edited it.
Reply 3 of 17, by kixs
Eh... you need 1024Kb cache chips. With 512Kb you only get 256KB. Tag is fine.
Visit my AmiBay items for sale (updated: 2025-03-14). I also take requests 😉
Reply 4 of 17, by Intel486dx33
Okay, thanks.
Reply 6 of 17, by appiah4
4 512Kb cache chips make 2048Kb of cache. 8 bits is 1 Byte, so 2048 Kb is 256KB; your cache is fine.
Reply 7 of 17, by GigAHerZ
Perfect!
Except, kilo is lowercased k, uppercased K is Kelvin. 😀
(No offence, just had to put my two cents in... 😜 )
Reply 9 of 17, by GigAHerZ
@Deksor, well, you can use both, but you are right - kilo is ALWAYS 1000 and never 1024, kibi is 1024.
Reply 12 of 17, by RiP
ph4nt0m wrote:
RiP wrote:
Why do some boards use 5 chips instead of 4 for cache memory? 😕
https://stason.org/TULARC/pc/motherboards/E/E … AY-EV-8038.html
There can be two tag chips. Sometimes it works faster this way.
Thanks for reply.
But actually, there are three tag chips, two bigger and one smaller at bottom 😕
Reply 13 of 17, by ph4nt0m
Thanks for reply.
Some boards can take an additional chip to make extended tags for larger cacheable range or in order to enable write back functionality. This 1x64K chip seems to do the latter.
My Active Sales on CPU-World
Reply 14 of 17, by GigAHerZ
Sometimes some motherboard have 1 chip for tag, and one chip for write-back buffering. 😉 (I have a 386 with that - doubles the memory write speed (Y) )
Reply 15 of 17, by ph4nt0m
PC Chips M321 ?
Reply 16 of 17, by RiP
Thanks all!
My mobos are EV-18108/EV-8038 and they have PC Chips too but not sure about the exact chipset.
Reply 17 of 17, by GigAHerZ
ph4nt0m wrote:
PC Chips M321 ?
Bingo!
