First post, by Dracolich
Hi guys, I've read some existing threads on this concept but didn't find a clear answer to my idea. I want to use two Creative cards together - a PnP AWE64 Value for sound and a non-PnP CT2260 for GM/OPL. The 2260 also has a Dreamblaster daughterboard attached. The AWE64 is currently installed and setup as A220 I5 D1 H5 P330 T6. The 2260 uses jumpers and is set the same.
My idea is to keep the AWE64 at the same settings, removing the AWEUTIL /S line from AUTOEXEC to prevent initializing FM emulation, configure the 2260 for different I/O, IRQ and DMA, then connect the line-out from the 2260 to the line-in of the AWE64. Is this a doable hybrid solution?
