Reply 11900 of 27554, by bjwil1991
I don't know if this is a true statement or not, however, have you used an ATX power supply that has the -5VDC or the ATX to ATX w/ -5VDC adapter to see if that fixes the whine? Could be capacitor issues.
Reply 11901 of 27554, by Caluser2000
138.73 KiB
Playing with my 386dx25 running wfw 3.11. Got Opera 3.62 set up and registered. Downloaded IE5 and NS4.08 to compare how they go. Opera renders pages a lot better and is faster. It does pop up an error box every now and again but if you select ignor a couple of times it does recover fine without kicking you out or locking up windows.
Reply 11902 of 27554, by canthearu
liqmat wrote:
On that third card there is jumper block JP3 and JP4, but I don't have a clue what their settings are
Switch both those jumpers over, you will get much better quality output from that 3rd ESS card because that will disable the onboard amplifier (you will obviously need powered speakers or an external headphone amp to use it this way of course)
But I agree, that card based on the crystal chipset looks like a beauty.
Reply 11904 of 27554, by appiah4
Those first two cards look like fine examples of OEM ES1869 cards, they should not be terribly noisy that chipset is fairly integrated and silent. That's strange.
Reply 11905 of 27554, by keenmaster486
Interesting. I have had the best luck browsing in Windows 3.1 with IE 3.0 or Netscape Navigator 3.04.
Netscape 4.08 works but can be crashy. IE 5 works but is slower.
I tried Opera 3.62 with catastrophic results; it would never really run properly at all and was pretty much useless. This was on a Pentium MMX. I wonder whether the slower computer somehow helps (speed-related bugs).
World's foremost 486 enjoyer.
Reply 11906 of 27554, by keenmaster486
Thermalwrong wrote:
That's brilliant did you take any pictures, or is there a page that had some details on it?
I didn't take any pictures, but here's the YouTube video I used to help me get my bearings around what was inside:
https://www.youtube.com/watch?v=oZpPZM5nRpM
Reply 11907 of 27554, by liqmat
I was thinking the same thing, but I just don't have time to work on recapping anything right now. I had some noise issues with a few PCI sound cards as well on the same test mobo and PSU so I will mix it up today and see if it improves with a different mobo and PSU.
Thank you! I'll give that a try. That's exactly what it sounds like on the third card down. Like the amp is cranked all the way up on a cheap stereo system. Even when I mute all audio channels in the mixer it's still there. As far as the Crystal card goes I always assumed they were cheap knock-off sound cards, but this particular card changed my mind on that. One of the better wavetable chips I've listened to.
Reply 11908 of 27554, by PTherapist
I've been playing with a lot of old 8-bit micros & 8/16-bit games consoles recently and so a few days back I decided to dig out my NES.
It had lay unusued and gathering dust for nearly 25 years and was practically a human hazard when I unearthed it from it's resting place. There was dust, dirt & grime all over it and some weird green gunk inside the cartridge slot and over several pins.
Armed with isopropyl alcohol, cotton buds & kitchen towel, I set about cleaning it all up to a liveable standard, but didn't have a power supply nor any games in order to test it out.
Fast forward to today and the game I ordered to test it with arrived - Super Mario Bros (plus Duck Hunt, but I have neither the gun nor a CRT TV).
My Power Supply hadn't arrived yet, but thanks to sheer luck I happened to find in my drawer 1 of those multi voltage changing plugs which lacked any DC cable on the end. After a bit of cable splicing, I had this thing up and running and it's working great. 😎
Just waiting on various items that I've ordered now - a replacement front door/flap, a 2nd gamepad & a 500-in-1 Games Cartridge to fully put this thing through it's paces. In the meantime, I need to practise some Super Mario in glorious Composite Video & Mono Sound. 🤣
Reply 11909 of 27554, by appiah4
For the first two cards, J6 is a similar jumper. It's from left to right Up, Mute, Down for volume level, it probably defaults to UP. Just jumper the rightmost two pins closed for DOWN and you'll get clear sound from them.
Those cards are Acer OEMs btw, Acer FX-16 to be exact.
Reply 11910 of 27554, by gdjacobs
liqmat wrote:
Tested four ISA sound cards tonight on my tech bench Slot 1 motherboard. The top two ESS Audiodrive cards both have a high pitch whine to them in Windows 98SE and are rather noisy (white noise) over headphones. The third ESS Audiodrive card is so noisy with hiss and white noise it is almost unusable. On that third card there is jumper block JP3 and JP4, but I don't have a clue what their settings are. All three have noise artifacts coming from other devices hooked into the motherboard such as hard drive access noise, mouse movement noise, etc. The fourth card is actually my favorite. It has a Crystal chipset and if you look closely towards the rear of the card that's a Crystal CS9236-CL wavetable chip which actually sounds rather incredible with MIDI tunes. It also is the least noisy of the four cards. I vaguely remember ISA sound cards having a slight hiss to them, but some more than others it appears.
Those two jumpers are for amplification on or off. One is for the left channel, the other for the right.
Reply 11911 of 27554, by liqmat
That did the trick on the third card. Thanks a bunch. After all these years of doing this I somehow missed there were jumpers that toggled the internal amp of a sound card. Learn something new all the time in my case. Your suggestion also fixed the Avance Logic sound card I posted about one page back. J4 and J5 on that card disable the very noisy internal amp. It sounds very clean now.
Actually J6 is for remote volume control and mute. Thanks for pointing it out though because it made me investigate deeper and it turns out J5 controls the amp. Much better now so thanks for jump starting my brain.
Yep. you are correct and thanks.
All of you guys have been super helpful and my ears thank you for it!
Reply 11912 of 27554, by badmojo
I didn't know about inboard amp jumpers until I joined this forum either - louder was always better for me back in the day and my speakers were generally the biggest I could find in the local hard rubbish so I probably wouldn't have cared anyway 😵
Reply 11914 of 27554, by Turbo ->
gdjacobs wrote:
I've successfully used CS4232 drivers from Turtle Beach, although I don't really care about the 3d function of the CS4289 companion chip. Also, IMO the FM reproduction of the companion chip is absolutely nasty.
appiah4 wrote:
I have the exact same card, it's a Crystal CS4232, use Crystal's latest drivers and it will work perfectly fine.
Thank both of you. I found Crystal CS4232 drivers in Vogons library and installed them. When testing it in DOS with games like Lotus and Secret of the Monkey island it worked great. But when testing the card in DOS with games Prince of Persia and Day of the tentacle, it had issues with midi sound (doors closing, falling, jumping - is this called midi?) Changing the IRQ and other setting had the same or even worse affect. The computer also froze for two or three times. Had to reset it with button. But when I installed Turtle beach drivers which were luckily in the same folder, I did not occur problems.
Yet another ISA sound card in my collection is saved 😀
Reply 11915 of 27554, by GigAHerZ
Got a ATI Rage Pro Turbo PCI 8MB graphics card and upgraded to it from Matrox Millenium 4MB in my Pentium MMX machine.
Monster Truck Madness 2 can now actually run with DirectX acceleration! (Y)
Reply 11916 of 27554, by Deksor
No it's not "midi" sounds. Midi is a music standard, basically it holds the informations on notes, instruments and etc to be played by a synth, which can be anything, including the Yamaha OPL3 (or a clone).
Theses sounds are just regular sounds.
Reply 11917 of 27554, by appiah4
That card has no MIDI wavetable so you should NOT be using MIDI for music or sound effects in those games. For Prince of Persia just select Adlib for music, for day of the tentacle it should be 100% compatible with SB Pro for Music and Sound. If it crashes on using digitized SB Pro sounds, try using regular SB option, if that also fails it may be a weird IRQ or DMA conflict, would need to know more about the setup.
Reply 11919 of 27554, by keenmaster486
But is it supported? I can't use anything if it's not supported. Because everyone knows only supported software works, ever. I want my entire computer to be supported. Supported supported supported!
