Carmageddon and GliDos
First post, by ChrisEvans
I recently download a copy of GliDos to see if it would make one of my favorite old games, Carmageddon Splat Pack, work on my modern system.
Foolishly, I only tested the first level before I paid $10 to remove the spinning logo. Now that I`ve actually played the game through a proper I have noticed a large number of texturing bugs.
The problem is at it's worst on the island map, hell map and the medival castle map although the texture bugs affect all the cars and all the maps to some extent. Many of the textures flash random psycadellic colours, it makes the game quite unplayable!
I tried a diffrent Glide wrapper "dgVoodoo" which fixes the problem (while creating some new problems I`m not going to go into right now) so it seems obvious to me that the texture bugs are caused by GliDos.
I have trawled though this message board and nobody seems to be talking about strange texture bugs, has anyone else had this problem? Does anyone know how to fix it?
Chris
Reply 1 of 13, by Glidos
Strange. What graphics card and driver?
Reply 2 of 13, by Guest
nVidia GeForce 6600GT
driver version, hmm, fairly new ish, I`ll have to go home and check (I`m in work right now) will reply when I know.
P.S. sorry about the duplicate post, I fucked up 😀
Reply 3 of 13, by Guest
Sorry, fogot to ask,
Do you know a driver verison a defo works?
Reply 4 of 13, by Glidos
Really shouldn't be a problem with that card. Two things worth trying:
1) Try an older version of OpenGlide from the Red Baron page of the web site. It gives you an alternative version of Glide2x.dll, which you can put in C:\Program Files\Glidos, in place of the one that is currently there.
2) Try psVoodoo. Again, its an alternative Glide2x.dll
Reply 5 of 13, by Guest
I tried both the Glide2x.dlls you suggested, they made a diffrence, now it looks even worse 🤣!
I found out what driver I`m using:
6.14.0010.8195 according to dxdiag
I`ve attached a picture of the game so you can see for yourself.
I would like to point out I get exactly the same problem on my work PC.
Reply 6 of 13, by Gambit37
Just a quick aside: please compress your BMP into JPG format. BMPs are way too big and a waste of good bandwidth. Thanks.
Reply 7 of 13, by ChrisEvans
If the moderator could take my old post down (I can't seem to edit a guest account post), I have uploaded a .jpg verion.
Reply 8 of 13, by Glidos
It would be interesting to see the different results from the different versions. Might give a clue as to what's going on.
Reply 9 of 13, by Glidos
Hey, try this. Its an alternative glide2x.ovl. Bung it in C:\Program Files\Glidos. Probably wont help, but worth a go.
Reply 10 of 13, by Glidos
Any luck with that?
Reply 12 of 13, by Glidos
The new Glide2x.ovl? Any luck with that?
Reply 13 of 13, by Glidos
If anybody tried this version of GLide2x.ovl, it would be handy to know, especially if it worked.
