First post, by Predator99
Hi, is anybody able to identify this board? Looks very nice but it doesnt run. Maybe its a faulty BIOS, but I dont know where to look for an image? I add mine for reference, but maybe its bad...Thanks!
1.75 MiB
Dualp2-17008.rar
117.27 KiB
24 downloads
Reply 1 of 5, by luckybob
At first I thought it was an IWILL DBD100, but the chipset heatsink and bios sticker are a dead giveaway for pc-chips.
http://www.motherboards.org/mobot/motherboard … s&mobos_id=M720
Reply 2 of 5, by luckybob
so I'm looking it over, and its missing the APIC chipset. So its a single-cpu board unless you find that little board that goes into that little slot to the right of the bios.
GOOD LUCK.
Reply 3 of 5, by Predator99
WOW thanks luckybob! 😎
PC Chips M720. Doesnt seem to be worth to spend more time with. Already asked what this slot may be used for. Now I also found a BIOS file that has only 471 different bytes to mine..! I will try that one and if it doenst work..away with it 😵
PS: Did you had a chance to test the ATI card in the mean time? 😉
