First post, by paltrude
In addition to this post:
See DOSBOX.txt attached to this message.
See sysspec.txt attached to this message.
Game: X-Com "UFO Enemy Unkown" v1.2
System [Software] tweaks: I have tweaked the system by disabling services that isn't needed, nothing system critical but some nonsense services that runs by default on startup. Mostly RAM garbage anyhow...
Problem: Game performance problems [Slow Sound and Graphics] while running "combat mode", both flying and ground combat, probably due to my settings in /etc/DOSBOX.CONF
Is it the renderer? [What renderer should I be able to use? OpenGL, something else?] I have tried pretty much them all, they vary in performance of course but the end result seems the same.
Is it the soundcard sb16? [GUS is disabled]
Is it the amount of RAM [32] allowed to DOSBOX? [I can easily allow more for DOSBOX, before starting dosbox i have more than 300mb free]
Or have you got some other idea?
I get pretty nice glx statistics in "glxgears" [18880+ frames in 5 sec =3770+ FPS in 1024*768] so I doubt that it is related to the graphics card or driver, rather my graphics settings in DOSBOX. I feel that my machine, which seems to run nicely with DOSBOX 0.63 as it is, should perform a little bit better than it does while playing the game.
I might be wrong but then perhaps you can enlighten me as what to try next?
The readme helped me identify most of the stuff I could do, I am pretty fly [for a white guy 🤣] on the DOS and hardware side but I gather some specific DOSBOX and X-Com1 experiences and hints from you expert users are needed in this matter.
Patience comes to those who ... wait?
